P/S fluid - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-13-2007, 08:07 PM Thread Starter
belowme's Avatar
Date registered: Jan 2007
Vehicle: 99 ML320 , 03 ML320
P/S fluid
MB brand only or can we use others ?
belowme is offline
post #2 of 6 (permalink) Old 11-13-2007, 10:45 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 226 Post(s)
MB purists will tell you that you must use MB brand but I've had Valvoline SuperSyn in my ML430 for about 6 months and in the ML320 for about 1 month. So far, no issues and they're both actually quieter. The MB brand is NOT synthetic.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 6 (permalink) Old 11-14-2007, 01:54 AM
Wolfgang's Avatar
Vehicle: MBs
Hello Mitch. Looks like that is actually approved by Mercedes.
Here's the list:
Approved Dexron III Automatic Transmission Fluids for M-Class W163 Power Steering
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257/22096
Chevron ATF Dexron III F-30108/30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Texaco ATF Mercon/Dexron-III F-30321
Pennzoil ATF D-22413/F-30110
Quaker State Dexron-III/Mercon F30161
Sunoco ATF Dexron-III/Mercon F-30176
Unocal Multi-Purpose ATF D-22413/22431
Valvoline ATF Type D
Wolfgang is offline
post #4 of 6 (permalink) Old 11-14-2007, 06:06 AM
Date registered: Jan 2004
Vehicle: 2004 ML500,Sport; 2009 ACURA TSX
Quoted: 40 Post(s)
I would recommended MB fluid and it's not expensive. One bottle will last you a long time.
JM.
johnma is online now
post #5 of 6 (permalink) Old 11-14-2007, 06:58 AM
Wolfgang's Avatar
Vehicle: MBs
JM.
That is Mercedes part number Q1460001 for a list price of $8.50.
MBUSA recommends both:
MB Power Steering Fluid for W163 M-Class
MB Part No. BQ 1 46 0001
or an approved Dexron III ATF (see above)
Wolfgang is offline
post #6 of 6 (permalink) Old 11-14-2007, 08:17 AM
cmitch's Avatar
Quoted: 226 Post(s)
Here's the list:
The stuff I use is Valvoline 'Synpower' fluid. It is nearly crystal clear and doesn't smell as bad as the MB stuff.
cmitch is offline
Windshield washer fluid container not holding fluid... Jayhawk W220 S-Class 18 02-26-2015 07:17 AM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 11 08-17-2006 04:31 PM
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 10:59 AM
Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
replacing rear pads and brake fluid, and tranny fluid,... ewalberg G-Class 3 03-25-2005 09:15 AM
