» Site Navigation
» Other Sites
Old 11-10-2007, 06:34 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 1985 380sl
2000 Ml430: Heater Always On
Hello,
I recently purchased a 2000 ml430 with 80,000 miles on it. It seems to be by and large in good working order except for the heating. I don't know why but it always seems to be on. Even if I turn the fan all the way down if I put my hand over the vent I can still feel a little bit of warmth emanating from it. When I put the fan intensity to 2, the heating is overwhelming. Temperature intensity doesn't seem to have an effect on anything.
What should I check next?
-George
Georgeous is offline   Reply With Quote
Old 11-10-2007, 08:04 PM   #2 (permalink)
Date registered: Feb 2006
There is another knob selecting temp on the side. Is it missing ?
>>>>>No
Sorry I overlooked your last statement about "temperature intensity".
mlfun is online now   Reply With Quote
Old 11-10-2007, 09:47 PM   #3 (permalink)
If you found the temp knob, does the airflow change as you turn it from hot to cold and vice versa ?
Old 11-11-2007, 01:59 AM   #4 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
I agree with mlfun. Does the temp. change? Is the heat coming out of the center vent only? Give a little more info.
43sqd is online now   Reply With Quote
Old 11-11-2007, 03:41 AM   #5 (permalink)
CAHEK's Avatar
Date registered: Apr 2006
Vehicle: ML 320
that's easy
make sure to turn off both temperature and fan dials and it will stop blowing hot air.
CAHEK is offline   Reply With Quote
Old 11-11-2007, 07:52 AM   #6 (permalink)
Date registered: Feb 2005
Vehicle: 2000 ML430
Such strange answers! One should always be able to have ambient temperature air blowing into the cabin.
Obviously, something is wrong with the climate controls.
DelJ
DelJ is offline   Reply With Quote
Old 11-11-2007, 07:55 AM   #7 (permalink)
Vehicle: 2000 ML430
The heater is always "on" in the ML430 as far as the heat exchanger is concerned; the system works by opening or shutting the heater vent. It appears that your heater vent controller is stuck open.
And yes, that heater does get quite warm when fully open!
DelJ
Originally Posted by Georgeous View Post
Hello,
-George
Old 11-11-2007, 09:07 AM   #8 (permalink)
CAHEK's Avatar
Vehicle: ML 320
DelJ
i agree that hot air blowing in your face is pretty strange especially when you just turned it off, but this workaround does the trick.
Old 11-11-2007, 11:10 AM   #9 (permalink)
DelJ
Sounds like it.
But if you are lucky, only the temp sensor is busted.
Old 11-11-2007, 01:02 PM   #10 (permalink)
Vehicle: 1985 380sl
So after further observation, changing the position of where the air is blowing doesn't seem to have an effect on heat intensity. If turning the air temperature knob all the way into the blue I do perceive a slight reduction in heat but it is still definitely heating the cabin. So for this reason I believe it might be the heat valve slightly but not completely working.
So, where is this valve, could someone please put up some pictures or point me to a diagram please?
-George
Looking to Buy a 2000 ML430... Scott M W163 M-Class 5 10-15-2007 10:35 AM
2000 ml430 navigation cd dynahart Audio & Telematics Forum 7 07-14-2006 03:15 PM
Will 2001 Ml430 transmission work in a 2000 ml430? orlandotrader W163 M-Class 3 02-24-2006 04:31 AM
2000 ML430.... Benz Boy 07 W163 M-Class 5 08-08-2003 10:20 AM
2000 ML430 Bill Mostellar W163 M-Class 6 01-30-2003 05:44 AM
