What is the life span of an OEM battery? - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 10-16-2007, 09:10 AM Thread Starter
dominic888's Avatar
Date registered: Feb 2006
Vehicle: 2002 ML 320
Red face What is the life span of an OEM battery?
I have a 2002 ML320 purchased in December 30th of 2001, current it has 77,050 miles. I have all standard equipment, no exceptional power hungry electronics. When do I have to repalce the battery? I don't want to be stranded with a dead battery.
Dominic
dominic888 is offline
post #2 of 21 (permalink) Old 10-16-2007, 10:30 AM
alphonsohall's Avatar
Date registered: Nov 2004
Vehicle: ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
Quoted: 17 Post(s)
I've just replaced my battery after six years and one months service from the original one.....even then it was still ok but beginning to be just a little sluggish on cold morning starts, that was the sign for me to change it.
alphonsohall is offline
post #3 of 21 (permalink) Old 10-16-2007, 10:36 AM
JimB's Avatar
Date registered: Jul 2002
Vehicle: ML320/C320 Sprt
Unhappy I've changed mine
every 3 years, in fact mine just went dead this morning. This is 3rd battery in 7 years @90K miles.
2000 ML320 Black Opal "SOLD"
2003 C320 Sport Sedan Bordeaux Red
1996 Honda Civic...
1991 Black Nissan Truck
2005 Honda CR-V EX AWD...New Add on to my Toys...
2012 Subaru Outback LIMITED
Trek, Full Suspension Mt. Bike
and a Dog, name Abby;-)
"Life is Short, Let's Enjoy It"
JimB is offline
post #4 of 21 (permalink) Old 10-16-2007, 12:19 PM
geordie's Avatar
Vehicle: 2002 SLK32AMG,1995 E320 Cab 1990 300CE(Gone).2002 ML320 (Gone)
Quoted: 15 Post(s)
In my experience your battery is on borrowed time
Our 2002 ML320 has got 81,000 miles and we're on our 3rd battery.
In my experience Mercedes batteries typically last 3- 4 years.
You're doing well.
Geordie
VA USA
2002 SLK32///AMG
1995 E320 Cabriolet
geordie is offline
post #5 of 21 (permalink) Old 10-16-2007, 12:53 PM
clearchris's Avatar
Date registered: Sep 2007
Vehicle: 2000 ML320 (x2)
Quoted: 74 Post(s)
If you are considering an aftermarket battery, here are my experiences.
If you get a Sears Diehard battery, the battery is shorter than the OEM battery. I put a slotted chock of wood on top of the battery to give it enough height so that the stock battery strap would hold the battery down. I have also noticed greater than normal corrosion on the negative battery terminal of this battery to the point where it required a battery post shim.
Interstate batteries offering fits better and I haven't seen the same corrosion issues as with the Diehard.
clearchris is offline
post #6 of 21 (permalink) Old 10-16-2007, 01:12 PM
MADSLEG's Avatar
Date registered: Jun 2005
I have original battery that was made in 1997 in Spain
Still good !
Had same question-WHEN ? ))
MADSLEG is offline
post #7 of 21 (permalink) Old 10-16-2007, 02:13 PM
MJ50's Avatar
Date registered: Nov 2003
Vehicle: W204 & W211
Quoted: 17 Post(s)
if nothing is draining ur battery, then it should last at least 4-5 years...
W211 | W204 | W163 | W203
MJ50 is offline
post #8 of 21 (permalink) Old 10-16-2007, 02:26 PM
Vehicle: 2000 ML430
Still going strong after 7.5 years and 80,000 km.
HarmsWay is offline
post #9 of 21 (permalink) Old 10-16-2007, 06:22 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 216 Post(s)
Mine lasted nearly 8 years. I changed it because the wife left a rear light on and drained it completely down. I was afraid that trying to save it would eventually cause a crap out because complete drain downs weaken a battery considerably, especially an old one.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #10 of 21 (permalink) Old 10-16-2007, 06:30 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
how much is a battery from the dealer? Not for them to install just to buy and DIY.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
    Battery life GPS W210 E-Class 7 01-28-2008 10:58 PM
    Battery life Merc owner W124 E,CE,D,TD Class 5 05-08-2005 09:07 PM
    battery life ? oil_burner W126 S,SE,SEC,SEL,SD,SDL Class 4 02-22-2003 11:07 AM
    Battery Life.... William Monte W163 M-Class 1 03-23-2002 07:34 PM
    life span of HID bulbs? Sammytx W163 M-Class 3 01-03-2002 08:18 PM
