I have working power and heated seats!!! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-11-2007, 10:31 AM Thread Starter
Vehicle: 2002 ML320
Thumbs up I have working power and heated seats!!!
For those of you following my interior upgrade project on my ML, the good news is that I have functioning full power and heated leather seats were before I had manual, non-heated, deteriorating vinyl/cloth seats. The new seats look and feel great. The bad news was that this was not a DIY job. Sure, it started off easy. I pulled out my original seat, found the exact match female wire harness under the seat, plugged it in, and then easily mounted the seats. I then added the missing relay socket, relay, and fuses. As for the heated seats, after I removed the MCS and the wood trim there were the two harnesses for the heated seat switches. I purchased two new switches and then went to work on the wood trim piece with my dremmel. The switch bracket was right there but there was no hole for the switch so I had to make two of them. Pretty straight forward job, just go slow, then I installed my switches and put it all back together. Even the light for the heated seat came on but I had no heat and no power to my seat adjustment. For that I had to visit the MB dealer for help. There, seat guru Dave figure out the wiring, add a harness that was missing from behind the interior fuse box, and repined some of the existing harnesses. I could not have done this. It took 5 hours and cost me $500 but I’m okay with that. We’re keeping the ML for a few more years and having these features added to replace pieces that were wearing out will make the next 5 years more enjoyable. And I only paid $350 for the entire interior. Thanks to everyone who helped me with advice on my install. Now onto the door panels and the rear seat. I’ll post some before and after pictures once I’m done.
2002 ML320, black, inspiration leather interior, 7 passenger seating, MB DVD system
jeff968 is offline
post #2 of 5 (permalink) Old 10-11-2007, 11:09 AM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 68 Post(s)
Congratulations! -- I was wondering what had happened. I sure you will enjoy the Leather, Power and especially the Heated seats.
Mike
Mike's ML is offline
post #3 of 5 (permalink) Old 10-11-2007, 04:57 PM Thread Starter
Vehicle: 2002 ML320
Yeah, it took a day or two before "Dave the seat Guru" freed up. Thanks for all your help Mike!!!
jeff968 is offline
post #4 of 5 (permalink) Old 10-11-2007, 05:10 PM
asianml's Avatar
Date registered: Sep 2005
Congratulations!! If I recall correctly you bought Inspiration Edition seats, right? It must be stunning.
asianml is offline
post #5 of 5 (permalink) Old 06-09-2008, 03:26 AM
SA_ML320's Avatar
Date registered: Feb 2006
Vehicle: 1998 ML320
Hey Jeff, out of interest did you buy the entire seat or just re-cover the existing one. The reason I ask is that one of the seat motors for the power adjustment in the passenger seat is broken and MBSA tells me they will only sell me the entire seat adjuster which is about $2200! So was pretty surprised to see your $500 price tag...
Which leads me to a little rant - this is the second time where MB's parts stocking policy makes the cost to repair literally 1000 times more than it should be. I've had the plastic clips on the sunroof wind deflector go and they'd only sell me the entire deflector assembly at $100. Thats at least $99.5 more than if I could just replace the clip. Needless to say I don't have a working deflector...
Cheers.
SA_ML320 is offline
    Rarity of a 300SDL w/power and heated rear seats mace W126 S,SE,SEC,SEL,SD,SDL Class 9 03-16-2011 08:25 AM
    Electric Power Seats no Working.. AC_ML W163 M-Class 2 03-26-2008 10:21 AM
    Heated seats on 500SEC - Half working? davidrivers W126 S,SE,SEC,SEL,SD,SDL Class 7 04-17-2006 02:00 PM
    Power seats quit working??? HELP!!! stikystikyricky W163 M-Class 2 03-15-2004 04:57 PM
    Power seats not working ? Guest (MBNZ) W124 E,CE,D,TD Class 7 05-18-2002 05:31 PM
