proper way to jumpstart a ML? - Mercedes-Benz Forum
post #1 of 32 (permalink) Old 10-11-2007, 05:40 AM Thread Starter
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 99 infiniti i30 limited edition
Just out of curiosity, what is the proper way to jumpstart a ML? I read somewhere that you do not leave your key in the ignition while it is being jumpstarted so how would you start the truck? Sorry for my ignorance.
busoptr is offline
post #2 of 32 (permalink) Old 10-14-2007, 02:12 AM
DETANE's Avatar
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
Don't jump start ever. What you do is get your self a Booster for about $30- $200.
http://www.nextag.com/battery-booster/search-html
You connect the wires to the battery and allow the Booster battery to allow you to crank the engine. Once you start your engine disconnect the Booster and close the Hood. Take your ML for a spin and allow the battery to charge. Battery while not charge well if at idle so please drive for a few miles before you turn your engine off. Trust me on that one
Hope that helped
Life is the thing that gets in the way of plans.
DETANE is offline
post #3 of 32 (permalink) Old 10-14-2007, 03:16 AM
alphonsohall's Avatar
Date registered: Nov 2004
Vehicle: ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
Quoted: 17 Post(s)
Battery Booster - Compare Prices, Reviews and Buy at NexTag - Price - Review
Hope that helped
Surely connecting to a donor vehicles battery using jump leads (donor engine stationary) to jump start is no different than using a battery booster?
What's the difference?
busoptr....I think removing the key from the ignition issue applies when you disconnect/reconnect the ML's own battery.
alphonsohall is offline
post #4 of 32 (permalink) Old 10-14-2007, 07:02 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 980 Post(s)
It's still amazing how a rudimentary task like jumpstarting a battery has to be discussed.There is no special way of jumpstarting an ML as opposed to any other vehicle. None whatsoever. There are so special components in an ML that millions of other vehicles do not have.
Most, if not all, problems arise from not correctly hooking up the cables. Positive to positive and negative to negative. Some accidently reverse them, others don't think it matters, but most of these errors happen at night. Once that happens the cash register starts warming up and sounds its' familiar tone. Batteries can explode and computers and modules start to burn up. Why because when you reverse polarity, everything that should be getting positive is now getting negative and vice versa. When a battery is half dead an accidental reversing can be caught in time because of the apparent high sparking involved. But not on a fully dead one. When the cables are reversed there is no forewarning and that's when electronics start to cook and wiring starts to melt.
Electronic keys go bad for a reason and probably the biggest one is error in jumpstarting. Removing one's key from the ignition, when jumpstarting, is always a good idea with any vehicle. Doing so will minimize battery drain but most importantly it will protect at least the key from damage in the case of a reversing error.
43sqd is offline
post #5 of 32 (permalink) Old 10-14-2007, 09:46 AM
Panzer Man's Avatar
Date registered: Apr 2006
Vehicle: 2005 ML500SE
It is amazing to me how many people either don't have an owner's manual, or don't read it. In my 2005 owner's manual on pages 291 and 292 is a very detailed procedure of the proper method of jump starting an ML. It's not rocket science!!
Panzer Man is offline
post #6 of 32 (permalink) Old 10-14-2007, 03:21 PM
DETANE's Avatar
I dont know if you noticed but some of the guys asking the question drive a 1999 or a 2002 and dont have your 2005 manual. (Just my 2 cents)
DETANE is offline
post #7 of 32 (permalink) Old 10-14-2007, 03:27 PM
DETANE's Avatar
Well you could connect jumper cables to another persons car battery if the engine is off but then of course your draining the other persons battery (Not Nice) and might leave the stranded too. Get a Booster, Save your self the trouble of getting stranded and waiting for road side to aid you (Unless you need the company I guess). JK
My next move is having 2 Optima yellow tops running parallel (one for the start, one for the toys)
DETANE is offline
post #8 of 32 (permalink) Old 10-14-2007, 04:20 PM
Panzer Man's Avatar
I had a 2000 430 and it had a manual. I'm sure every year has had a manual. Because I now own a 2005 500 it was my only reference. For those that don't have a manual. Here's how it goes. Pos to pos and neg to neg always. Hook pos to your battery then pos to other vehicle battery. Hook neg to your battery. At this point start other vehicle and let idle ( thus no power spikes ) then attach neg to other vehicle. After your engine starts, unhook neg from other vehicle, then your vehicle. Same with pos! Same as I did 45 years years ago in cold Montana winters when I drove a wrecker!!
post #9 of 32 (permalink) Old 10-14-2007, 08:10 PM Thread Starter
busoptr's Avatar
i know about the pos and pos and neg and neg, what I'm asking is they said if you leave your key on while jumpstarting, the key electronics will be fried.
busoptr is offline
post #10 of 32 (permalink) Old 10-14-2007, 08:47 PM
Panzer Man's Avatar
Make the final connection of the neg jumper cable to the neg post of the other battery, insert the key in your ML, and start the engine, remove the neg cable from the other battery, and you're finished! It makes no mention of leaving the key in or out of the ignition during this procedure in my owners manual! Bye the way I had a sign on the wall in my office that said"Who the hell is they".
Inoperable speedometer, ABS & ASR lights on due to "crossed" jumpstart petern12 W140 S-Class 8 01-24-2011 10:31 PM
ML320 died after jumpstart Nobie W163 M-Class 13 10-11-2006 02:46 PM
Got Jumpstart - Breaks & Battery Immediately Acting Up d2e W123 E,CE,D,CD,TD,TE Class 14 01-15-2004 07:12 AM
Problems due to Jumpstart? raphster W140 S-Class 2 02-07-2003 07:09 PM
Electrical problems after jumpstart... Chas G-Class 3 08-12-2002 08:01 PM
