» Site Navigation
» Other Sites
Old 09-21-2007, 03:12 PM   #11 (permalink)
asianml
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
Originally Posted by Mike's ML View Post
What were you thinking Bogie was thinking? If you were thinking what I'm thinking that Bogie was thinking then I'm thinking your thinking is not that innocent either.
Mike
You think?
asianml is offline   Reply With Quote
Old 09-23-2007, 07:32 PM   #12 (permalink)
Builder2961
Builder2961's Avatar
Date registered: Sep 2006
Vehicle: 2001 ML320 W/ D2 Nav and XM Traffic, 2000 Audi S4 Stage 3
I wouldn't mess with it. I simply installed the Pioneer antenna on the dash inside the car right next to my XM antenna. If you would like a picture let me know. The D2 sees all the birds fine.
Builder2961 is offline   Reply With Quote
Old 09-24-2007, 10:08 AM   #13 (permalink)
Builder2961
Step By Step Installation AVIC D2 For 2001 ML320
Good Step by Step install DIY also tells you to defeat parking brake safety
Old 09-24-2007, 10:17 AM   #14 (permalink)
tomcat7
tomcat7's Avatar
Date registered: Aug 2007
Vehicle: 2000 ML430
Just got system installed this weekend. I'll take pics and post. I have a little different approach on the antenna because some people said they had trouble with the Antenna inside. I pulled the factory antenna, fed the wire thru the hole, used the magnetic plate inside the car and used hot glue to seal around the wire coming out. Not quite as clean a look as I would like but only can see really close. I plan to use a little black calking to smooth the seal.
tomcat7 is offline   Reply With Quote
GPS Antenna? Evangelist W163 M-Class 13 12-13-2005 01:42 PM
How to use GPS antenna in rear view mirror as an external antenna for aftermarket GPS systems ianx, manchester R171 SLK Class 9 08-03-2005 01:57 PM
GPS Antenna My04230k W203 C-Class 1 12-04-2004 02:15 PM
GPS Antenna 00 ML430 Bulldog W163 M-Class 3 06-09-2004 06:22 AM
ML GPS antenna Iwan W163 M-Class 2 03-07-2002 11:50 PM
