Old 08-28-2007, 07:43 PM   #1 (permalink)
Date registered: Sep 2005
HELP!! AC fan
I have a 1998 ML 320. The AC fan started to make a funny noise and the dash sort of vibrates. sounds like there is something caught in the fan (hope it wasn't alive!). I cleaned the filter but still makes the sound and vibration. would like to know how to get into the fan blades/motor housing to see if there is something caught in the blades. It still blows, but not as good. Any help is appreciated.
mnp8888 is offline   Reply With Quote
Old 08-29-2007, 12:32 AM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Remove the black cover again under the right side of the dash, remove the electrical connector to the blower motor and then remove the bolts holding the blower motor. After you drop it down you will probably find that something is lodged in the squirrel cage causing it to be unbalanced.
Before you put the blower motor back in, reconnect the elec. plug, grab a hold of the lower part of the motor, turn the controls on to operate it so you can assure yourself that the problem is gone. Also vacuum the blower cavity out to make sure you get all the debris removed.
43sqd is online now   Reply With Quote
Old 08-29-2007, 05:06 AM   #3 (permalink)
Bogie's Avatar
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
Good to know! Thanks!
Bogie is offline   Reply With Quote
Old 08-29-2007, 07:40 AM   #4 (permalink)
Thanks so much. Will try that today. I have found I can do a lot of these types of repairs on this car, to my surprise. I appreciate your help. I have had a couple of weird problems, one which the dealer said had never happened on one of these vehicles in the US (driver side airbag ignitor went off without deploying the airbag - thought I had been shot!) and now the gas tank seems to have come loose from its brackets and the nozzle intake has dropped about 1" and the "check engine" light came on, don't think this will be a cheap or easy fix at the dealer. Thanks again.
Old 08-29-2007, 03:22 PM   #5 (permalink)
Vehicle: 02 ML320
The check eng. light came on because when the tank dropped, it kinked or disconnected a hose attached to the filler neck. These hoses are hooked up to the Evap. System, which will throw a code.
The fuel tank is supported by two straps, which are not expensive at the dealer (about $20 each). Needless to say your problem is very dangerous and should be repaired ASAP before further driving.
Old 08-29-2007, 04:12 PM   #6 (permalink)
Date registered: Feb 2006
No sh*t. If the fuel tank drops, its bbq time.
mlfun is offline   Reply With Quote
Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
Replacing clutch fan for thermo fan... baskarz W126 S,SE,SEC,SEL,SD,SDL Class 0 04-10-2007 09:02 PM
Bolts for fan/fan clutch tmoc W163 M-Class 2 07-13-2006 12:28 PM
126 HVAC Fan not working / Heater Fan Removal cam69ss W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2005 10:31 AM
Electric Fan v's clutch fan Christian G-Class 0 03-16-2002 05:13 PM
