Old 08-25-2007, 10:12 AM   #1 (permalink)
Date registered: Sep 2006
Kick down button faulty?
HI,
I have a 1999 ML 320 and it appears to have NO kickdown - How do I access the kick down button to check it? I can see it, but can't work out how to get at it!!
Thanks
rogeruk is offline   Reply With Quote
Old 08-26-2007, 04:11 AM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Try this procedure posted by another memberSlk230UK99
Date registered: Jun 2005
Vehicle: 2002 ML 320
Posts: 280 Resetting throttle parameters..
Got this from the slk forum... better throttle response and smoother shifting for most who have tried it on their auto slk's. I tried it on the slk and it works a treat... havent tried it on the ML yet but I'm sure I'll notice a difference.
" Resetting throttle parameters
Method 1.
1. Turn key to ON (before start)
2. Press throttle all way down
3. Hold for 5 secs
4. Turn key to off.
5. Release throttle.
6. Wait for 2 minutes.
Keep the key in for the entire time.
See how you go[] Seems to work for most who have tried it.
43sqd is offline   Reply With Quote
Old 08-26-2007, 03:50 PM   #3 (permalink)
Tried this, this is what makes me thinks the button isn't working, as doing this had NO (zero) effect on the ML!
The switch 'clicks' but nothing happens.
Old 08-29-2007, 12:48 AM   #4 (permalink)
alphonsohall's Avatar
Date registered: Nov 2004
Vehicle: ML 270CDI 2002
Originally Posted by rogeruk
HI,
Thanks
Could be a faulty MAF...............?
alphonsohall is offline   Reply With Quote
Old 08-29-2007, 01:38 AM   #5 (permalink)
steve57's Avatar
Date registered: Aug 2007
Vehicle: Ml430 1999,black paint,with black leather interior ,+ command
hi roger
i had the same problem with my ml 430 .i was a faulty maf ,fitted new maf now all ok.
steve
steve57 is offline   Reply With Quote
Old 08-29-2007, 04:40 AM   #6 (permalink)
thanks! will check this out - fule consumption is pretty poor (even for an ml) so sounds 'bout right!
Daft question - how do I check it is bad without buying a new one? Can I disconnect it and see if anything happens or does this screw up the ECU? I've had a look at it - it looks intact and clean...but...
Old 08-30-2007, 04:29 PM   #7 (permalink)
Ok - problem sorted!
I removed the kickdown switch (eventually) - checked it and cleaned it - checked resistance with meter - all ok.
Cleaned MAF with carb. cleaner.
Reset ECU.
Went for drive - wonderful! different car!!! Actually drops a gear in kickdown to overtake - made wife say slow down - so must be ok!
Thanks for the help everyone - and to anyone else - clean your MAF!!
Transmission Kick Down AtomicAgeBrando W126 S,SE,SEC,SEL,SD,SDL Class 4 01-21-2007 09:59 PM
Kick down cable vambulance General Mercedes-Benz 1 01-17-2007 07:04 PM
kick down jabus38 W163 M-Class 22 12-04-2006 10:07 AM
Kick Down Button ifrad W124 E,CE,D,TD Class 1 07-25-2005 12:03 PM
cup holders,trunk release button,console button with tire picture maci911 W140 S-Class 2 10-04-2004 04:01 PM
