White/yellow mucous like sludge in the coolant reservoir - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 08-20-2007, 10:03 AM Thread Starter
Date registered: Nov 2005
Vehicle: 2001 ML 320
I have a 2001 ML 320 with about 100Kmi on it. I have recently noticed that I have a white/yellow mucous like sludge that is gathering on the roof of the clear coolant reservoir tank that is at the back of the engine. When I unscrew the cap I see can see this sludge. I have also noticed a dark layer of liquid floating on top of the coolant. I have checked all the oil fluid levels in the car (ie oil, transmission, power steering, and brake) and none of those systems seems low enough to indicate a leak.
Has anyone seen this before? Do I just need to get my cooling system flushed because I have 100Kmi on the car? Do I have a crack in the system, and oil/fluid is mixing with the anti-freeze?
Another thing I have noticed, I am not sure if it is related, is that when I turn on the A/C for the first time on a hot day, after the car has been sitting for a while I smell a sweet odor coming out of the vents, but it goes away after about a second. Is the heater core cracked problem?
Any ideas on how to debug these problems?
Many thanks in advance!
edogd1 is offline
post #2 of 20 (permalink) Old 08-20-2007, 10:10 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Sounds like engine oil is getting into your coolant.... normally a head gasket problem....
keyhole is offline
post #3 of 20 (permalink) Old 08-20-2007, 11:08 AM
Date registered: Apr 2004
Vehicle: ml 320 1998
sludge
Hi mate this is a common problem when the car is not run enough, ie, doing short journeys, i know cos ive suffered, but when i took it on a long run going on holiday, with a sludgy oil cap when i reached my destination i checked the cap and it was all gone, i was told by a merc dealer i was doing more harm to the car than good going on short journeys,etc, the car was made to drive hard, every now and then.
dont worry its not the head gasket.
regards.
gravel is offline
post #4 of 20 (permalink) Old 08-20-2007, 11:51 AM
Bogie's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
This may or may not have been gravel's issue, I'm not so sure that it's so easy to rule out a head gasket. It sounds to me also, that you have oil in your coolant. I would track the problem and address it as soon as possible.
Bogie is offline
post #5 of 20 (permalink) Old 08-20-2007, 12:40 PM
bogie im only saying, my opinion as ive had allllllll the faults thats been talked about on the forum, im only trying to give advise, and where not to spend alot of money,
A head gasket costs alot of money, with labour, cats cost money,£££££££&# 163;£££££££. every ittle thing helps,
this site has saved me alot of money with the advise from alot of people, in the US, you lads seem to be able to throw alot of money to your car i wish i could, all im trying to do is give advice.
Been there!
gravel is offline
post #6 of 20 (permalink) Old 08-20-2007, 12:52 PM
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99ML320 (retired) C230 530xi 911-C4
regards.
Gravel - you are correct if the sludgy thing is on the OIL FILLER cap.
This owner appears to have this sludgy thing on his/her COOLANT FILLER CAP.
Hence the possibility of a head gasket failure.
roadsession is offline
post #7 of 20 (permalink) Old 08-20-2007, 01:16 PM
sos i dived in again.
gravel is offline
post #8 of 20 (permalink) Old 08-20-2007, 02:58 PM
ziska1999's Avatar
Date registered: Jan 2007
Vehicle: 1999 ML320, 2001 ML320, 1982 380SL, 2006 ML350
Sounds Bad
White / Yellow gunk does sound like oil in the coolant. Be happy its not orange. If it were orange foam then it would be tranny fluid in the coolant. That would be worse!
ziska1999 is offline
post #9 of 20 (permalink) Old 08-20-2007, 05:11 PM Thread Starter
Well I am putting into the shop so that they can do some testing (ie compression testing, and hydro-carbons testing the anti-freeze) However, I fear the worst may be true; head gasket failure and replacement of many coolant system hoses and parts. I will keep you posted. Thanks for the tips thus far.
edogd1 is offline
post #10 of 20 (permalink) Old 08-20-2007, 05:30 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 32 Post(s)
When did you last change the coolant? I was thinking head gasket but since you're not overheating in this hot weather, I'm beginning to think it's just bad coolant from not changing in 100K. If you did do your coolant change regularly, then you're doing a good thing to go to the shop.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
    Oil in the Coolant reservoir john2007 R/C107 SL/SLC Class 10 08-08-2007 07:02 PM
    High pressure coolant reservoir - same stuff? Qualm W124 E,CE,D,TD Class 2 12-04-2006 07:20 PM
    Coolant fluid reservoir? eurobluebenz W123 E,CE,D,CD,TD,TE Class 13 05-09-2006 01:23 PM
    Had sludge in my coolant. dirtyhands W201 190-Class 3 04-06-2006 12:37 PM
    Coolant Reservoir Airbus W126 S,SE,SEC,SEL,SD,SDL Class 3 04-03-2006 02:00 PM
