Just recently, the ETS & EPS & Brake indicator lights came on accompanied by loud beeping (as if my door was ajar with the keys in the ignition).
This doesn't happen all the time; but when it does happen, it's only when I'm driving forward or reverse. When I'm stopped at a light, the beeping stops, but then resumes once I accelerate. Sometimes I can get the lights and beeping to turn off by shutting down my engine . . . sometimes not.
Somedays I can drive all day without any indicator lights coming on or the anoying beeping noise that goes with them.
I've already had my brake switch change . . . not the solution.
Any clues would be greatly appreciated . . . Thanks.
Your problem is one of the biggest issues disacussed on this forum. There are so many posts on this issue you will go blind reading them, with solutions from brake light switch, battery, steering angle sensor, speed sensor, alternator, shorts and a myriad of other cause and effect solutions.
With that said, keep in mind that this problem can be caused by many different things and while it worked for one member does not mean that it will work for you. Replacing the brake light switch was a good choice, but did you check to see if the BRAKE LIGHTS are coming on when you apply the brake? Also do a search on the forum for RESETTING THE STEERING ANGLE SENSOR and see if that works.
well I was today at a Car repair shop in Laguna Beach, CA and we checkt the ML with the orig Mercedes Winstar Diagnostic Programm.
Well to Problems show up :
1. Wheel- Speedsensor
from the front rigth Wheel is faulty ( it shows aktion but the car was not moving) .
2.
a very new Solution and never see befor on Benzworld ...... the Relais NR. 25
( ETS Relais in the Fusebox ).
We change the Relais with a other relais what is located in the Fusebox ( same Type ).
