Old 08-14-2007, 08:55 AM   #1 (permalink)
dewdaltz's Avatar
Date registered: Oct 2002
Vehicle: 02ML320 & 06RClass
PO304 - Cylinder misfire on #4
did search but there was no indication on how hard or easy for the DIY. Thinking of changing all the sparkplugs, plug wires, whatever included in the Tune-ups (please let me know for parts) by myself. Any more tips on the these.
Quote 4 da` day : MODDING is very essential to make your ML very SPECIAL
dewdaltz is offline   Reply With Quote
Old 08-14-2007, 03:12 PM   #2 (permalink)
dewdaltz's Avatar
any help/technique on how to remove the spark plug wire from the coil. thanks.
Old 08-14-2007, 06:58 PM   #3 (permalink)
mclass13's Avatar
Date registered: Jun 2007
Vehicle: 2000 ML55
You turn the wire back and forth while pulling it until it pops out.I recommend u take the coil out of the engine its more easy.
mclass13 is offline   Reply With Quote
Old 08-15-2007, 02:51 AM   #4 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Also try a 17mm open end wrench. Place it around the metal shielding and use it to pry off the wire.
43sqd is offline   Reply With Quote
Old 08-15-2007, 10:53 PM   #5 (permalink)
Date registered: Jul 2007
Vehicle: ML 320 Sport.
I just changed my plugs two weeks ago. It took me about three hours and a few cuts and bruises.
Actually there is a forum on changing plugs right here with diagrams and everything. I just forgot the link but I used it to change mine.
Kr1sta is offline   Reply With Quote
Old 08-16-2007, 09:30 AM   #6 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
Hi dew,
first of all, try to replace it with oem spark plugs
remove all the ignition coils on the driver side of the engine for extra access space
use 17mm open wrench to pull the spark plug cables off the plugs
use a pivoting and angled socket wrench to loosen the spark plugs
replace all the cables with new ones
take your time and make sure you put the cables in the right way. The drivers bank and the passenger side does not have the same pattern.
busoptr is offline   Reply With Quote
Old 08-16-2007, 10:48 AM   #7 (permalink)
dewdaltz's Avatar
Originally Posted by busoptr
Hi dew,
Very BIG Thank you. I will follow your advice. But you forgot one thing - have some COLD beers on the side.
Old 03-15-2008, 09:25 AM   #8 (permalink)
Date registered: Nov 2007
Vehicle: ml500 w163 2002
did you figure out what happened with cyl #4?
RUEY220 is offline   Reply With Quote
Misfire cylinder 4 5 or 6 alloyduk W210 E-Class 8 08-23-2007 02:07 PM
Cylinder Misfire Codes Help slybydesignw210 W210 E-Class 2 05-05-2007 05:28 PM
Cylinder Misfire? lon000007 W163 M-Class 6 08-22-2006 10:38 AM
PO 304- cylinder #4 Misfire!! pchansen1 W140 S-Class 5 05-10-2006 07:13 AM
Cylinder Misfire? ///S320 W140 S-Class 4 12-14-2003 08:18 AM
