Old 08-02-2007, 08:24 AM   #1 (permalink)
laxman0324's Avatar
Date registered: Nov 2005
Vehicle: 1997 Nissan Pathfinder SE
Send a message via AIM to laxman0324
restore engine treatment
I decided after my last oil change to use the restore engine treatment that has all the commercials, and i was very impressed. Before i thought the ML was just designed to be very sluggish unless really pushed. After using it the engine feels so much smoother and revs to any rpm without feeling like im pushing it too hard or something. I just thought I would share this information with you all. Bye the way the mileage is now at 223,000
http://4x4country.net/register.php?REF=8187
1999 Mercedes-Benz ML 320 - updated headlights and chrome grill strips...sold
1996 Honda Accord LX - 2.2L 4cyl and newly replaced exhaust pipe and muffler, 17x7 ADR Venomous Rims...stolen
1997 Nissan Pathfinder SE - Clear turn signal lenses and Ravens spare tire cover
laxman0324 is offline   Reply With Quote
Old 08-02-2007, 08:56 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Did you use the pellets thru the spark plug holes?
Kajtek1 is offline   Reply With Quote
Old 08-02-2007, 09:08 AM   #3 (permalink)
laxman0324's Avatar
no i used an additive that you put in with the oil. they have different sized cans for how many cylinders your engine is. I went to a couple different shops like pep boys and autozone and asked my service advisor at the stealer and they all said this is the best treatment to use. it was 20 bucks for that and a bottle of the stuff you put in your gas tank that cleans the injectors and all. the smartest 20 bucks on my mercedes so far
Old 08-02-2007, 01:34 PM   #4 (permalink)
Date registered: Sep 2005
Vehicle: 2001 ml 320
would you happen to have the name of the product
benzmoy is offline   Reply With Quote
Old 08-02-2007, 03:34 PM   #5 (permalink)
Date registered: Jun 2007
wow over 200,000 miles,,and still kickin..awesome..only if benz paid more attention to the electronical stuff as much as they did with their engine, the truck is flawless..keep up the maintanance and u can add another 200,000 miles..good job..i will try it on my truck,, so what exactly is the products name>>??and what fuel injector cleaner did u get,,how many bottles>>thanks
CHiEsAMG is offline   Reply With Quote
Old 08-02-2007, 07:59 PM   #6 (permalink)
laxman0324's Avatar
The product is called Restore. They have a 4,6, and 8 cylinder formula, each with different sized bottles. Go to your local Pep Boys and check it out. The fuel treatment is by STP called Complete Fuel System Cleaner. Well worth it.
Old 08-02-2007, 09:36 PM   #7 (permalink)
laxman0324's Avatar
sorry i posted the wrong pic the second time. this is wat the restore bottle looks like
Old 08-02-2007, 09:42 PM   #8 (permalink)
Date registered: Oct 2004
Vehicle: 00 ML55, 06 E500, 87 325(project), 91 supra T(sold)
Send a message via AIM to 55fanatic
If you have never tried it... I might recomend using Sea Foam... Works AMAZING
55fanatic is offline   Reply With Quote
Old 08-03-2007, 12:26 PM   #9 (permalink)
hockeyelmo's Avatar
Date registered: Jul 2005
Vehicle: 2000 ML 320
Isn't benz strictly opposed to additives in the engine oil??
2000 ML 320, Hella FF Lights, WAAG Front & Rear Guards, Manik Taillight Guards, Xenon Lights, Cross-Drilled Rotors, BF Goodrich ATs, Custom Alpine Sub System, Dynamat
hockeyelmo is offline   Reply With Quote
Old 08-03-2007, 12:40 PM   #10 (permalink)
WolfWinter's Avatar
Date registered: May 2005
Vehicle: 1999 ML 430
I cant belief that MB would approve of that?? Enlighten me. The last time I used a similar product on an old clunker the head gasket was starting to leak after 1000 miles....hmmm
I wish I had a Kryptonite cross, because then I could keep both Dracula AND Superman away!
WolfWinter is offline   Reply With Quote
Restore engine restore? Good or bad for MBs 240DieselPower W123 E,CE,D,CD,TD,TE Class 27 04-02-2007 04:40 AM
Petrol treatment Rajinder_1 R129 SL Class 2 07-14-2006 02:55 PM
Fuel Treatment? BeauBaby R170 SLK Class 4 06-15-2006 06:46 AM
Wax 'treatment' G-Benz230 R170 SLK Class 6 02-14-2006 05:30 PM
OT: G - Disparate Treatment?!... woodyww W163 M-Class 7 08-28-2003 12:38 PM
