» Site Navigation
» Other Sites
Old 07-30-2007, 09:15 PM   #1 (permalink)
What Else To Expect Next?
I have a 2000 ML320 with 110K miles on it. I have had to replace the mass airflow sensor, crank position sensor, brake light switch all within the last 6 months because they all started to fail. I will need new torsion bar bushings soon since one bushing is already gone. Is there any other fixes that I should expect soon?
Thanks to all, this forum has helped me diagnose all my ML320 problems.
lochatun is offline   Reply With Quote
Old 07-31-2007, 01:15 AM   #2 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
cabin filter
busoptr is offline   Reply With Quote
Old 07-31-2007, 05:36 AM   #3 (permalink)
Date registered: Jul 2007
Catalysts, A/C compressor, purge valves, plugs (assuming that they were done around 60K which appears to be the norm)
We have done all of the above + tires on my wife's '99 (118K miles) over the past three months - something north of $5K on a car that is worth, perhaps, $9-10K.
Had I known 4 months ago that this was all coming, someone else would own it now!
Ecurie_Martini is offline   Reply With Quote
Old 07-31-2007, 06:06 AM   #4 (permalink)
WolfWinter's Avatar
Date registered: May 2005
Vehicle: 1999 ML 430
Did you check all the recalls? Harmonic balancer,very important.
Torsion bar bushing or sway bar bushing?? The one going the length of the car or the front bar sitting in front of the wheels?
I wish I had a Kryptonite cross, because then I could keep both Dracula AND Superman away!
WolfWinter is online now   Reply With Quote
What to expect ? RedLiner R129 SL Class 5 01-17-2007 09:02 AM
What to expect? Skookill R170 SLK Class 1 06-11-2005 06:09 AM
what else should i expect to fix? iNeon W123 E,CE,D,CD,TD,TE Class 0 04-07-2005 04:00 AM
What can I expect? chevdo W140 S-Class 4 01-25-2005 01:48 PM
What to expect? Guest (MBNZ) General Mercedes-Benz 1 04-18-2002 05:54 AM
