Old 07-29-2007, 04:24 PM   #1 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
after installing new cats, 02 sensor heater circuit codes on both sensor 2s
Hello! I had my cats changed and like 4 days later, I get a CEL and the codes are p0141 and p0161, so I know its both 02 sensors that are located after the cats. Is this normal? Did the new cats do this? Or should I just replace both 02 sensors? Anyone?
busoptr is offline   Reply With Quote
Old 07-29-2007, 05:28 PM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
make sure they didnt come disconnected.
Streetglower is offline   Reply With Quote
Old 07-29-2007, 10:28 PM   #3 (permalink)
busoptr's Avatar
will do streetglower. It could be water on the connectors too someone told me at the shop. thanks
Old 07-30-2007, 11:03 AM   #4 (permalink)
busoptr's Avatar
streetglower , youre right , one of the 02 sensors downstream was loose, but the one on the driver side was intact. Do I replace the drivers side?
Old 07-30-2007, 04:10 PM   #5 (permalink)
I would clear it and see if it comes back
Old 07-30-2007, 07:26 PM   #6 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
If you do get the O2 sensor codes again, change them. If they were bad in the first place, they would have caused your ML to run rich. This could have caused the damage to the cats.
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 07-31-2007, 12:15 AM   #7 (permalink)
busoptr's Avatar
No the codes did not come back.
Old 07-31-2007, 12:18 AM   #8 (permalink)
busoptr's Avatar
I found a secret to clearing the codes without waiting for the cycles and the 30 minutes like somebody on the forum posted. A benz technician told me this, to clear codes without the code reader, all you gotta do is disconnect your negative wire on your battery and then with your car key, turn your ignition to on but not start for 15 seconds and leave it there. After 15 seconds, take off your key, connect the negative wire and presto, the code is erased. Now dont forget guys you got it from me LOL
P0136 and P0141 codes--which O2 sensor 1984_500sel W140 S-Class 1 03-10-2008 03:48 PM
P0130 Sensor Circuit Malfunction. okiloveu W210 E-Class 2 05-21-2007 04:53 PM
P0133 and P0136 Ox Sensor Codes Set Yositimy R170 SLK Class 1 09-01-2005 07:20 PM
P0136 and P0141 codes--which O2 sensor (S500) 1984_500sel W126 S,SE,SEC,SEL,SD,SDL Class 0 07-29-2004 08:52 AM
O2 sensor and check engine light codes... ewalberg G-Class 3 04-21-2004 01:09 PM
