Old 07-25-2007, 12:01 PM   #1 (permalink)
Date registered: Jul 2007
Question ML 320 Passenger Headlamp replaced
I just had our passenger side headlamp replaced and have noticed that the cruise control doesn't work and also the brake lights are constantly on. Is it possible that the shop that replaced the headlight did not set the wiring back up correctly on the headlamp replacement and it is causing this two things to happen. I have noticed that the cruise control function and the headlamp function are both on the left side of the steering wheel. Let me know what you think.
Kimber52 is offline   Reply With Quote
Old 07-25-2007, 01:01 PM   #2 (permalink)
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2000 ML 430, 2007 Scion tC
Sounds like you need a new brake light switch, easy DIY, see http://www.benzworld.org/forums/w163...+switch+repair
azinn is offline   Reply With Quote
Old 07-25-2007, 01:11 PM   #3 (permalink)
Question
Thanks. Will this take care of the cruise control as well?
Old 07-25-2007, 01:28 PM   #4 (permalink)
Vehicle: 1990 190E, 1998 ML320, 2005 ML500
It should. They are related.
Mike
Mike's ML is offline   Reply With Quote
Any one Help Please Vito Passenger Headlamp Vito Owner V-Class 7 06-29-2008 12:55 AM
replaced entire front passenger door lock unit bigcatny W163 M-Class 2 02-24-2004 09:16 PM
ML 320 to be replaced by the ML 350 by the end of the year nabzy W163 M-Class 11 08-10-2002 12:21 PM
Will an slk 320 eisenmann exhuast work on my clk 320? Same year too. bib W208 CLK Class 0 12-13-2001 07:51 AM
S500 vs S430/320 Driver vs Passenger Guest (MBNZ) W220 S-Class 1 05-18-2001 04:48 AM
