» Site Navigation
» Other Sites
Old 07-16-2007, 09:34 PM   #1 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
No fuse in F40 for vacuum pump
Hello I have 2000 ML 430, I was checking the fuses today in the fuse box and noticed that there was no fuse in the f40 slot. Is this normal?
busoptr is offline   Reply With Quote
Old 07-17-2007, 01:24 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
well look at the fuse diagram and see what it says. no every fuse slot is filled. also there is no vacuum pump on a ML. only the diesel will use a vacuum pump as the engine doesnt produce any vacuum.
Streetglower is offline   Reply With Quote
Old 07-17-2007, 11:21 AM   #3 (permalink)
busoptr's Avatar
oh okay, thanks streetglower.
Low vacuum on booster line. Do I need to rebuild vacuum pump? dentate gyrus W123 E,CE,D,CD,TD,TE Class 6 04-18-2007 06:58 PM
Vacuum pump rebuild kit or whole new pump 81bobby300D W123 E,CE,D,CD,TD,TE Class 1 03-31-2007 10:51 AM
Vacuum pump? Stevenpfaff W123 E,CE,D,CD,TD,TE Class 2 06-15-2006 02:00 PM
380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
Vacuum Pump $$$ Dingo Dave W140 S-Class 12 10-17-2004 11:48 AM
