Old 07-24-2007, 12:46 PM   #11 (permalink)
kenyee's Avatar
Vehicle: ML320
Originally Posted by seninha
Problem is that they can only deliver the shocks, and what I need are the springs.
Not sure if it's the same in Holland, but in the US, the springs *only* come w/ the rear shocks. You can't order them separately. To make it more confusing, if you buy 3rd party Bilstein rear shocks, they don't come w/ springs, so you have to take off the old springs and install them over the Bilstein shocks if you go that way.
I'd personally just use OEM rear shocks...
kenyee is offline   Reply With Quote
Old 07-24-2007, 02:47 PM   #12 (permalink)
Don't konw about Holland but you can order custome springs from race shops or performance shops here in US. Just a thought.
jjml55 is offline   Reply With Quote
Old 07-25-2007, 04:32 AM   #13 (permalink)
seninha's Avatar
Date registered: Jun 2005
Vehicle: 1999 ML 320
Send a message via MSN to seninha
Well, I already find different shops that deliver the rear spring, but they all lower the car.
And thats just one thing I dont want.
God's right foot!
seninha is offline   Reply With Quote
Old 07-25-2007, 07:21 PM   #14 (permalink)
BETO's Avatar
Date registered: Oct 2002
Vehicle: 03 ML500
Get the ID (inside diameter) and the OD (outside diameter), measure the length of the unloaded spring, and then contact any reputable spring manufacturer like H&R and I'm sure you can get them.
FOUR WHEELING IN STYLE. THE LEGEND CONTINUES.
BLACK 99 ML320
SILVER 03 ML500
08 GL320?
BETO is offline   Reply With Quote
Shock/spring rear everycredit W203 C-Class 10 07-14-2007 06:22 PM
brabus spring install recommendation needed mifidi The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 03-30-2007 10:44 AM
Help Ml 320 Rear Spring ? STAN1 W163 M-Class 13 02-25-2007 03:05 AM
Purists Beware - Spring Chopping Advice Needed streetrules W123 E,CE,D,CD,TD,TE Class 21 09-06-2005 04:55 AM
Broken rear spring MBZ933 G-Class 11 04-22-2005 03:15 AM
