» Site Navigation
» Other Sites
Old 07-15-2007, 12:40 AM   #1 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
can a faulty left front speed sensor activate the ets safety feature falsely?
ML has been diagnosed with left front speed sensor ( open circuit in wiring ) , I was wondering if this also could cause the yellow triangle light to flash and activate the ets in a over sensitive way? Is there anyone here who can help? Somebody?
busoptr is offline   Reply With Quote
Old 07-15-2007, 11:15 AM   #2 (permalink)
Wolfgang's Avatar
Vehicle: MBs
If a wiring malfunction like an open circuit to a speed sensor is sensed, then ABS, ETS and ESP switch off automatically, and can no longer activate.
Wolfgang is offline   Reply With Quote
Old 07-16-2007, 05:04 PM   #3 (permalink)
busoptr's Avatar
Thanks a lot Wolfgang. Forgive me for my ignorance, but does your answer say no to my question or yes? So, youre saying that even if I replace the front left sensor , those lights will still be on?
Old 07-16-2007, 07:53 PM   #4 (permalink)
Wolfgang's Avatar
Vehicle: MBs
Thanks a lot Wolfgang. Forgive me for my ignorance, but does your answer say no to my question or yes? So, youre saying that even if I replace the front left sensor, those lights will still be on?
busoptr, I would take the ML back to the mechanic who diagnosed the problem, and let him fix it. In the end this may be less expensive than replacing more parts which may or may not fix the problem. Usually with an open connection to a speed spensor the ABS malfunction indicator light should be lit up.
Here is a page from the owner's manual. Good luck.
Old 07-16-2007, 09:29 PM   #5 (permalink)
busoptr's Avatar
Hi Mr Wolfgang! I like that name. Anyways, thanks again for your help. Yes the abs light is on, ets and also esp. I will bring it back to the indy shop. Thank you so much.
youre the only one who posted help.
how to replace left front speed sensor busoptr W163 M-Class 2 07-14-2007 01:12 AM
can anyone help with left front speed sensor? busoptr W163 M-Class 0 07-13-2007 10:27 AM
activate the rain sensor wipers slik R171 SLK Class 6 12-19-2004 06:19 AM
cool new feature on the E class, wat is the function, safety light? Import Tuner Typ R170 SLK Class 10 07-15-2002 03:15 PM
New safety feature from MB... Norb USA R170 SLK Class 4 04-01-2002 10:55 AM
