Old 06-29-2007, 01:11 PM   #1 (permalink)
indpndntrd's Avatar
Date registered: Jun 2007
Vehicle: 2002 ML 320
Power steering Fluid Leak?
Recently I've noticed that there is a leak towards the front of my car.. The strange thing is that it only leaks sometimes.. There are days where I come out in the morning and there is a small puddle of fluid whereas sometimes there is nothing.. It does not feel like motor oil... Not as thick.. Looking under the hood it seems like it could be power steering fluid but a very slow leak.. Has anyone had this problem? My car is currently in the shop getting looked at....
indpndntrd is offline   Reply With Quote
Old 06-29-2007, 01:17 PM   #2 (permalink)
BenzWorld Post Whore
S4toML's Avatar
Date registered: Dec 2002
Vehicle: 05 C320 4MATIC
Smile There was a technical service bulletin about this a while back...
Originally Posted by indpndntrd
... it could be power steering fluid but a very slow leak.. Has anyone had this problem?
...the TSB was about a power steering hose recall. You may view the TSB in the link below:
http://babenj.tzo.com:6971/s4toml/mb...OSE_recall.pdf
2005 C320 4MATIC
<a href="http://babenj.tzo.com:6971/s4toml/gallery/" target="_blank">2003 ML350 Inspiration Edition</a></small></b></i> -- traded-in 11/2007
S4toML is offline   Reply With Quote
Old 06-29-2007, 05:44 PM   #3 (permalink)
Vehicle: ML430 - sold
if it's a slow leak, it's more likely the resevoir or the pump itself. The hose tends to let go big time and without warning - I should know I've had all of the afore mentioned three PAS problems.
Hopefully it's not your steering rack.
Tim (Formerly a senior race engineer / designer at Cosworth Racing UK for Formula 1 and CART engines)
'00 ML430
Replaced with Lexus RX400h 4x4 (0 to 60MPH in 6.5 seconds and 30MPG city)
My other 4x4 '03 Colbalt Blue Porsche Stage III 996 Twin Turbo (60 to 130MPH in 8.7 seconds and 12 MPG)
2005 Mini Cooper S, a pocket rocket
2002 VW Beetle, daily hack
Past cars of note:
'02 Porsche 996
'99 Porsche Boxster
timf is offline   Reply With Quote
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 10:59 AM
Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
power steering fluid leak jas322 W201 190E, D-Class 3 03-28-2006 03:28 AM
Hydraulic Fluid/Power steering Fluid panzerwagon_350slc General Mercedes-Benz 4 09-07-2005 10:06 AM
Power Steering Fluid Leak BenzRider2001 W163 M-Class 1 03-26-2005 11:59 AM
