ML320 water leak - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 06-26-2007, 09:03 AM   #1 (permalink)
Date registered: Jun 2007
ML320 water leak
My '99 M320 is currenting suffering from a water leak. First thing the dealer said was sunroof drain tube most likely. Took it in today, they had it for around an hour and simply came back with its not that, we will need it for a day for diagnosis. Thats going to cost.
The water is actually coming in through the dash. It only leaks when it rains. It is leaking out of one of the screw holes in the bottom of the dash into the drivers side footwell. Does that ring a bell with anyone?
I was going to attempt diagnosis myself. I am a bit concerned that the vehicle might be dangerous to drive. I haven't taken the dash off yet, but I presume there are electrics in the area and wondered if it should even be driven at the moment as we are experiencing bad weather. Can anyone advise?
ML320-99 is offline   Reply With Quote
Old 06-26-2007, 10:50 AM   #2 (permalink)
Date registered: Dec 2006
i have an 02 ml320 and i had a leak that was only apparent when it rained and when i washed it. It would condensate on the windshield and puddle in the driver's side floor board and soak everything. I thought it was the windshield too so i took it to the auto glass shop for an estimate or to get it re-sealed. Turns out it the sunroof drain tube "shrunk up"(his terms) at the sunroof and ran down the pilar into the dash and onto the floor. I had no electrical problems luckily and he fixed it for no charge in about 20 minutes. i've been leak free since
JTDUKE is offline   Reply With Quote
Old 02-24-2012, 07:11 PM   #3 (permalink)
Date registered: Feb 2012
My 2001 ML320 keeps getting wet whenever it rains. Yes, I have cleaned out the sunroof drains with compressed air, but it is still leaking. Does anyone have any suggestions on how to stop the leaks? Also my door locks are now broken, I was wondering how much that would cost(also need replacement keyless entry?)
PetersBenz is offline   Reply With Quote
Old 02-24-2012, 08:48 PM   #4 (permalink)
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430, 2006 BMW 325i, 2007 BMW 328i Coupe
Have the drain lines separated anywhere? You can check by pulling the a pillar off and seeing if they are wet on the outside. Start from the top down.
Sent from my iPhone using Autoguide
bocabenz is offline   Reply With Quote
Old 03-01-2012, 10:39 AM   #5 (permalink)
Date registered: Mar 2012
That's an interesting, I am having the same issue! Everytime it rains, there's leak all over the floor. It had to be inside the pillar. I ran thru a metal wire about 5 feet long to the drain, and metal came outside the pillar. how do i remove the pillar? do you just pry it open? I don't want to break the thing.
amarasig87 is offline   Reply With Quote
Old 03-01-2012, 11:49 AM   #6 (permalink)
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
All are the same issue - Both of you should check out the DIY thread for a fix. As I recall- thin piece of plastic wiring pushed down through clears the blockage - or as Boca said, it could be broken.
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline   Reply With Quote
Old 03-01-2012, 12:16 PM   #7 (permalink)
gotcha. Found that "how to" instructions. i appreciate it. i'll try this weekend
Old 03-01-2012, 04:19 PM   #8 (permalink)
mattko2000's Avatar
Date registered: Feb 2005
Vehicle: 98 ML320
water leak
I would check the drain hole on the right side cowl (outside by the windshield) it could be coming through the blower motor housing
mattko2000 is offline   Reply With Quote
Old 03-01-2012, 04:21 PM   #9 (permalink)
mattko2000's Avatar
Vehicle: 98 ML320
sorry you said drivers side not the pass side
Old 03-18-2012, 11:22 AM   #10 (permalink)
Good and bad news - I have found the source of the water leak. I had to remove the door sealer and part of the headliner. Then I took the bottom of the dash board off and saw the main problem. I poured a little water down the drain tube and saw the tube disconnected. But the problem is located next to the vent fan and my fingers can't fit in it. Any suggestions? I think it just needs to be reconnected because there is no connection on it. Any help would be much appreciated.
Bookmarks
WATER LEAK ? THE VIKING V-Class 2 02-19-2006 12:53 PM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
Water leak Malone W124 E,CE,D,TD Class 1 01-26-2005 10:51 AM
Water Leak! sss11 W126 S,SE,SEC,SEL,SD,SDL Class 0 10-10-2004 08:45 PM
Water leak Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 2 04-04-2001 03:16 AM
