» Site Navigation
» Other Sites
Old 06-24-2007, 07:36 AM   #41 (permalink)
ML430-OFFROAD's Avatar
Date registered: Nov 2006
Vehicle: 2000 ML-430 Polar White
ok, so another off road adventure to document, this is pretty impressive as well. I started going down this trail, which is asically in my back yard nad it was pretty tough. However, when i got a book i have and looked at it it gave this description. ( Trail Rating: Difficult, Narrow, Steep, Rocky. Muddy and slippery in places, especially early in the year. not suitable for stock vehicles)
here are some more pitures to enjoy...
Pick the right line
Who says I need a lift
ok, scout out a line... low range 1st. let Mercedes use the traction control with constant throttle control to maintain momentum. Traction control acts like a lcoker, minor slipping...
Brutal climb...
Sled run #1
you can sort of see it, but there was a big rock sticking a foot off of the embankment on the left at perfect height to put a new pinstrip on the lower porion of my doors... with careful stering of the sled and slow movements i squeezed by...
there was about 6 inches of soft sand and gravel in the middle of this from the way the water circled. i went through it twice... low range first is a MUST and constant accel made it all the way through...
where we're going, we don't need roads
ML430-OFFROAD is offline   Reply With Quote
Old 06-24-2007, 01:31 PM   #42 (permalink)
CAHEK's Avatar
Date registered: Apr 2006
Vehicle: ML 320
ML430-OFFROAD,
this is really impressive!
btw, did you check how deep the water was or did you just go through it?
CAHEK is offline   Reply With Quote
Old 06-24-2007, 01:39 PM   #43 (permalink)
Bogie's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
Yeah, how do I keep from having to post my own trail story that ends badly.
Bogie is online now   Reply With Quote
Old 06-24-2007, 05:15 PM   #44 (permalink)
I eye-balled it............. I just new that it was about the same amount as the water beofre. I was wrong, this water came well over the rockers and into the door sills. However, I have been disconnecting the filter from the intake only for the period i am in the water. Just unfasten the clips and separate the two pipes, then when out of the water reconnect them. That is a way of at least decreasing the chances of taking a gulp in the and blowing the engine. that water made it up to just below the headlight. I a m sure you know the intake is behind the low part of the passenger side headlight. One scary thing is a created a bow wave which greatly increases the chances. With the sand in the middle i started digging down some but was able to claw out, but the disturbance caused about 6 inches of water movement.
thats a great point, it is just really risky business because you can't tell if the ground is going to sink while you are driving over it or if a rock rolls out from under you and you fall in a hole. Who knows. I always try and keep m passenger side as high as possible, but i think mercedes is aware of its placement and most likely has some safeguards in place. Anyway, i am know expert, i just do it and if there is any question i change my mind, or i disconnect the lower part of the intake. Check this out though....
Mercedes Offroad
This is a lot different 4 wheeling than i do, they are looking for it, I cross all that difficult terrain and watercrossings to achieve a destination, and elevation, or just views, they seem to be doing it just to do it. But i was not in that much water and i was going a lot slower.
Old 07-09-2007, 02:46 PM   #45 (permalink)
Latest Adventure
Old 07-09-2007, 06:12 PM   #46 (permalink)
Bogie's Avatar
I can't tell you how much I want to go! Where the hell are you?!!!!
Old 07-09-2007, 09:33 PM   #47 (permalink)
I live in Colorado Springs, those pictures were 4.5 hours south in the San Juans. (near Lake City and Ouray to be more exact). If you are ever out here on a summer weekend and i am going, you are more than welcome to come along. I usually go every weekend anyway through august. here is a good site about Colorado.
MyColorado.org
I have not been posting my scenery pictures because i figured they were a little off topic. just pics of the ML
Old 07-10-2007, 11:19 AM   #48 (permalink)
Bogie's Avatar
Cool! If I'm ever out there, you can count on it! I am looking for similar areas in New England. Most places require you to park your car and hike. I have heard of places in western New England though. I'm looking forward to finding a path I can drive.
Amazing mr_benz General Mercedes-Benz 1 03-01-2007 08:53 PM
AMAZING... Guest W208 CLK Class 19 01-25-2006 08:08 PM
Amazing isn't it..... Chris_W124 Vintage Mercedes-Benz 0 08-14-2005 08:12 PM
Amazing! Parsifal W126 S,SE,SEC,SEL,SD,SDL Class 3 08-06-2005 02:46 PM
It's truly amazing... Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 23 04-19-2005 05:19 AM
