low range light - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 05-16-2007, 06:58 AM Thread Starter
low range light
hoping someone can help...
i have recently purchased an '02 ML500 , one owner, low k's, full dealer service history etc etc.
in the last week or two, the 'low range' warning light flashes for about 10 secs when starting up.
on calling the original dealer and explaining this, i was told that it needed a new 'low range motor' and this was common fault for this series.
so i guess my questions are
a. is this a common fault? (having scoured the first 12 pages i couldn't find a thread)
b. what is the part number for the low range 'motor' (as it was described to me)
c. is there an online seller of such parts.
any pointers appreciated!!
emel500 is offline
post #2 of 16 (permalink) Old 05-16-2007, 08:02 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
I understand that the low range motor is the one and same as some windshield wiper motors. You can get more info at: Wolfgang's ML Page: M-Class lockers
2005 S430 4Matic 'Morton' W220.183 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 16 (permalink) Old 05-16-2007, 08:09 AM
Vehicle: Black 2005 ML 500
low range light
There is a procedure described in the link below that you may want to try before buying/changing any parts.. I tried that procedure, too, and it worked fine for me.. There may be something getting out of sync from time to time..
AC
http://www.benzworld.org/forums/w163...ow+range+light
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Yokohama Geolander HTS + Bi-Xenons(+ Drew's e-code mod, though the reflectors rusted off and do not give out much light anymore), Yakima roof bars, Akebono pads all around. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After all these years of owning my current 2005 ML 500, it is a major unreliable vehicle with a very large/expensive repair/defect history and has been like this since brand new.
AC_ML is offline
post #4 of 16 (permalink) Old 05-23-2007, 03:04 PM
low range light
Just this weekend, I had this problem reappear. Everytime I started my ML the low range light will begin to blink.
I performed the steps described in the former posts, (starting the engine, putting it in neutral, pressing the low range button once, wait until it finish blinking (heard the low range motor engaging), turned off the low range by pressing once the button, waiting until the light stop blinking, and then turning the engine off).
After I restarted my ML, the low range light will not blink any more.. I am sure it will be ok for a couple of months. My former 2001 ML 320, never had this issue in all of it's 108,000 miles.
I wonder what is getting out of sync or when this happens. Maybe whenever I perform something in a particular order, it triggers this problem..?
AC
2005 ML 500
AC_ML is offline
post #5 of 16 (permalink) Old 05-24-2007, 03:48 AM Thread Starter
I tried that and it has worked.
thanks for the tips guys
emel500 is offline
post #6 of 16 (permalink) Old 05-24-2007, 07:30 AM
Date registered: Mar 2007
Vehicle: 1998 Mercedes-Benz ML320
I had the same problem and my mechanic just took the motor off and re-lubed everthing to get it unstuck. He told me about once a month, or more, engage low range and drive around the parking lot or if you have a short post office run, grocery store run, ect. do it in low range.
MLsteve84 is offline
post #7 of 16 (permalink) Old 05-30-2007, 02:28 PM
dannyqball_817's Avatar
Vehicle: 1999 ML320
I tried all of the above and mine is still coming on when I start my ML.
dannyqball_817 is offline
post #8 of 16 (permalink) Old 05-30-2007, 02:41 PM
low range light
Does your low range engage correctly when you turn on low range mode? If it does not, then you may have the low range engagement motor problem or some other issue. In my case, the low range motor engaged correctly, and only at startup would the low range light blink several times..
AC
2005 ML 500
AC_ML is offline
post #9 of 16 (permalink) Old 05-30-2007, 03:37 PM
Vehicle: 1999 ML320
I'm not really sure if it's working or not, I have only used it once and that was last winter. I turned it on and then drove it for a while but it didn't feel any different than it normally does. I'm assuming that is not how it's supposed to be.
If memory serves me correctly when I did have it in low range last winter it was like you put it in granny gear. I didn't feel anything like that when I put it in low this time.
The light only comes on when you first start it, it will blink about 4 or 5 times and then go out.
I didn't even think much of it until I saw this thread.
post #10 of 16 (permalink) Old 06-07-2007, 10:02 AM
MJ50's Avatar
Date registered: Nov 2003
Vehicle: W204 & W211
Quoted: 17 Post(s)
awesome... just tried it and the blinking went off! thx!
AC
W211 | W204 | W163 | W203
MJ50 is offline
    Low Range Light Flashing Joe W163 M-Class 21 01-09-2016 07:19 AM
    (problem) - low range light kept flashing soulsociety714 W163 M-Class 60 06-05-2012 01:44 AM
    Low Range & Fog light switch fell off 52cars W163 M-Class 10 07-12-2010 12:17 AM
    Low Range aeltohamy W163 M-Class 8 06-17-2005 12:44 PM
    Flashing Low Range Light jmd6936 W163 M-Class 3 09-23-2003 08:00 PM
