Part Number for Driver Seat Side Panel (ML320) - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 02-03-2012, 12:33 AM
Date registered: Jul 2005
Quoted: 972 Post(s)
Yes it is available. Dealer will need VIN for color code. It should be about $78
Call Jerry at MB of Naperville. Best prices in Chicago area on parts.
He will do 20% off list and have it shipped to your door for free.
Noodles is offline
post #22 of 28 (permalink) Old 08-25-2013, 08:34 PM
Date registered: Jul 2013
Vehicle: 2001 ML 320
Does anyone know where can I find this part now?
ltl2105 is offline
post #23 of 28 (permalink) Old 08-25-2013, 11:23 PM
Quoted: 972 Post(s)
Did you call Jerry at MB of Naperville in their internet parts department? 630-537-0312
It may even ship from MB's New Jersey warehouse. Either way Jerry can tell you the parts status as far as availability in your color.
Noodles is offline
post #24 of 28 (permalink) Old 08-26-2013, 08:57 AM
Thanks,
I will give him a call!
ltl2105 is offline
post #25 of 28 (permalink) Old 08-27-2013, 06:06 AM
Date registered: Sep 2006
Vehicle: 2000 ML320 / 1988 300SE / 1985 380SE / 1969 280SE
Is this item from ebay one you are looking for?
Hmm, I need the right one because the driver's seat is in the right hand here.
Kamikaze is offline
post #26 of 28 (permalink) Old 01-27-2014, 06:05 PM
Date registered: Jan 2014
Vehicle: 2000 ML 320
The part number you want is 163-919-39-20-1434. It's the Java color. I’ve just replaced mine. $83.00 before tax at a M-B dealership (AL). Before I bought it from the dealership, I’ve tried a few online stores. Those which did have it, quoted me about the same price.
L2RTe is offline
post #27 of 28 (permalink) Old 05-07-2016, 07:12 PM
Date registered: Mar 2015
Vehicle: 2001 ml430 and 2003 ml500
Fix
Figured out a cheap fix for this problem. The base of the recessed hole containing the trim scre breaks off. You can put a #00 rubber stopper (used in labs) with a hole in the opening. A # 8 trim screw then can be screwed into the stopper hole and the retaining hole on the seat . I used a 1 1/4 inch screw with the grommet part removed(wacked with a hammer). The stopper I used I cut the part off at the top where the OD was greater than the diameter of the recess hole on the trim. The stopper fits snuggly in the trim whole and reinforces it. Never going to break again. Stoppers I bought 5X Neoprene Stopper 1 Hole ? Green ? Size 00 ? ? Lab Supplies | eBay
bbb1007 is offline
post #28 of 28 (permalink) Old 05-23-2016, 12:33 AM
Date registered: Oct 2014
Vehicle: 2005 ML 350
Quoted: 39 Post(s)
like the stopper idea but i have had to rebuild seat bolster
to keep it from happening again and again
took off cover and cut broken foam out and glued and shaped new in.
now it doesn't crush down on the trim piece
kengarchow is offline
    Squeeky driver side seat joe_ca R170 SLK-Class 4 01-27-2004 07:10 PM
    Rattling in the driver side door panel brandon790 W163 M-Class 8 08-01-2003 02:19 PM
    third row seat part number..... Guwapo W163 M-Class 4 06-19-2003 07:18 PM
    How to open driver side door panel Guest (MBNZ) W202 C-Class 1 10-26-2001 09:46 AM
    water leaking into driver side rocker panel Guest (MBNZ) W210 E-Class 2 04-04-2001 03:51 AM
