» Site Navigation
» Other Sites
Old 03-02-2008, 02:11 PM   #71 (permalink)
clearchris's Avatar
Date registered: Sep 2007
Vehicle: 2000 ML320
One other tip... When you position your oil catch tray under the drain hole, give yourself a few inches back from the hole. The fluid comes flying out of there when you take the plug out.
I made a huge mess.
clearchris is offline   Reply With Quote
Old 03-11-2008, 02:33 PM   #72 (permalink)
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
Originally Posted by cmitch View Post
I thought I'd post this info since the transfer case fluid change is a hot topic as of late.
1. Do NOT put the car on wheel ramps! You want it as level as possible. You could preferrably jack up the front a couple of inches (secured with jack stands) so you can scoot under it. If you have access to a rack, that would be even better.
2. Remove the TOP fill plug FIRST by using a 3/8" ratchet extension end (fits right in the plug). It'll be tough because some kind of sealant was used to secure the plug.
You remove the top plug first in case the drain plug removes easily and the top plug cannot be removed. I wouldn't want you to drain your fluid and then be unable to remove the top plug to refill it.
3. Remove bottom plug and drain fluid (note: Dexron III transmission fluid is RED and what you're draining out will probably be black!). You may find metal shavings in the fluid. Whether this is normal or not is up in the air, but don't sweat it for now unless it's 'silver glop' instead of fluid you drain out! Replace drain plug.
4. To refill, use DEXRON III automatic transmission fluid, preferrably a reliable brand such as Valvoline High Mileage or Texaco. You will need some kind of bottle that will have a spout that will fit up to the top plug for refilling. I went to the Beauty salon supply store and bought an angled spout bottle that I could fill up with fluid and then empty into the hole. You could also use a sports drink bottle with an angled nipple.
5. Fill until it runs out the top hole. When this happens, you'll have about 1.8 qts. of fluid in the case. Replace top plug.
6. Drive you car for about 3000 miles and change it again!
It took 3 changes to eliminate my clicking noise. It is possible that this won't correct the problem on some vehicles and your transfer case may need replacing (forbid that to be the case!). I wish you well.
Here is a pic of the transfer case, courtesy of Wolfgang's ML page: Wolfgang's ML Page
Hope this helps some body.. Copy and past the link to your browser. It's a DIY Video.
http://www.youtube.com/watch?v=pp3IEd6ngcM
jealous people can suck a fat one!
DETANE is offline   Reply With Quote
Old 03-11-2008, 04:24 PM   #73 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
YouTube - Mercedes Benz DIY Tarnsfer Case fluid change
Great DIY!!! I noticed how black the fluid was that you drained out.
Be careful about reading health books. You may die of a misprint.- Mark Twain
cmitch is offline   Reply With Quote
Old 03-11-2008, 10:36 PM   #74 (permalink)
Yeah that was some dirty nasty oil that drained out. It's supposed to be red not black.lol
Old 03-12-2008, 09:54 AM   #75 (permalink)
Premium Member
cmitch's Avatar
Premium Member
I'd change it again in a 1000 miles.
Old 03-12-2008, 11:25 AM   #76 (permalink)
Date registered: Mar 2008
Vehicle: 2003 ML320
Fluid change
I have a 2003 Ml320 with 128k miles. Even though I haven't had any problems as of yet, should I have my fluid changed?
emplanner is offline   Reply With Quote
Old 03-12-2008, 11:43 AM   #77 (permalink)
YES!! did you see how black the oil gets. I think thats what causes the clicking sound in most trucks. preventative maintenance keeps the dealer away.
Old 03-29-2008, 04:49 AM   #78 (permalink)
dfskinner's Avatar
Date registered: May 2003
Vehicle: 1999 ML430
I'm planning to change them today, but I think it may be too late....... grinding in reverse and slipping and clicking in drive..... we'll see what's in the fluids when I take them out........ Just in case, anyone replace the "Transfer Case"? or know of anyone who's had it replaced?.......
Dennis
If you don't know where you want to go....
"Then it doesn't much matter how you get there"
1999 ML430
1998 Toyota Tacoma
1996 BMW 318is
2006 Mazada 5
2006 Infinity FX35
dfskinner is offline   Reply With Quote
Old 04-08-2008, 08:30 PM   #79 (permalink)
Originally Posted by dfskinner View Post
I'm planning to change them today, but I think it may be too late....... grinding in reverse and slipping and clicking in drive..... we'll see what's in the fluids when I take them out........ Just in case anyone every replace the "Transfer Case"? or know of anyone who's had it replaced?.......
I hear it costs about 2K-3K to replace it. If that was the case for me I think I would just part the car out and get some of my money back to buy another truck//
Old 05-28-2008, 06:00 PM   #80 (permalink)
Date registered: Feb 2008
Vehicle: 99 MB ML430/03 E500/02 BMW X5 4.4i
Send a message via AIM to Solidjake
hey, someone mentioned that they had a creaking sound before they did this. i have it when i have the car in D and when i let go of the brake. when i start to drive it goes away. will this fix that problem?
Solidjake is offline   Reply With Quote
front, rear differentials and transfer case fluid changed busoptr W163 M-Class 0 02-27-2007 10:32 PM
Transfer case and differential fluid change questions Michael Pillay W163 M-Class 14 06-02-2006 10:07 AM
Transmission/transfer case/diff fluid change? anyone have this done? MLnoob W163 M-Class 4 10-04-2004 09:37 PM
Transmission & Transfer Case Fluid Changed roadsession W163 M-Class 15 10-04-2004 08:10 AM
transfer case fluid... why mt-90 instead of 75w-90 ewalberg G-Class 11 08-07-2004 07:16 PM
