» Site Navigation
» Other Sites
Old 08-31-2007, 09:24 AM   #61 (permalink)
Date registered: Aug 2007
Originally Posted by cmitch
Refer to page 1 of this post. I posted pictures so there would be no confusion. It is no where close to the same as a transmission in looks. The transfer case has 2 drive shafts in it. One going to the front (short) and one going to the rear differential (long).
Ok, thanks!! I guess I'm a little confused what a transfer case exactly is? I know you have the transmission and differential but haven't really heard of a transfer case?
The fluid in both differentials has been changed... that I do know...
2000 Merc ML320
'99 BMW Z3 2.8 Supercharged
2004 Suzuki SV650
luciano136 is offline   Reply With Quote
Old 09-01-2007, 12:05 AM   #62 (permalink)
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
the transfer case is behind the transmission fluid pan.
busoptr is offline   Reply With Quote
Old 09-06-2007, 12:32 PM   #63 (permalink)
mendo's Avatar
Vehicle: ML350
Changed it last night.
found a great little pump at the NAPA store and was real easy.
did not come out too black, will do it again in 3000mi and see what it looks like then as well.
'Preciate all the info!!
mendo is offline   Reply With Quote
Old 09-06-2007, 07:58 PM   #64 (permalink)
mendo's Avatar
Vehicle: ML350
I have 1000mi on the transfer case oil change and the clicking is gone.
I will keep you posted.
'03 ML350 Inspiration Edition
Old 11-04-2007, 02:26 PM   #65 (permalink)
mortinson's Avatar
Date registered: Sep 2003
Vehicle: '91 G300D SWB Manual, '99 ML320 7 seater
Arrow Newbee here
Hello to everyone. I am new to MLs, being a long time GWagen owner and enthusiast. As such, I am very used to extensive preventative maintenance, such as changing the fluids in gearbox, transfercase and differentials, which have always been scheduled in the official maintenance for the GWagen.
My question is: are the fluid change of gearbox, transfercase and differentials listed in the scheduled maintenance for the ML. It appears to me that they aren't. Why is this so? I just bought a 1999 ML320 with 99,000 miles on the odometer and full main dealer service history for my wife, and I am worried that these things were never done to the truck.
The ML had its gearbox replaced by a brand-new unit 12,000 miles ago for the princely sum of € 5,000 ($ 8,000) so it is clear to me that preventative maintenance always pays...
Is there anything else, apart from the above, that I whould be concerned with in terms of maintenance?
Thanks in advance....
Mortinson
http://mercedesgwagen.galeon.com
mortinson is offline   Reply With Quote
Old 12-16-2007, 09:04 AM   #66 (permalink)
LiftdBlueML320's Avatar
Date registered: Jul 2007
Sorry, I haven't found that information either. I personally dont see any harm in changing them all now.
http://www.benzworld.org/forums/image.php?type=sigpic&userid=107706&dateline=1195833928
LiftdBlueML320 is offline   Reply With Quote
Old 12-27-2007, 11:18 AM   #67 (permalink)
got8's Avatar
Date registered: Dec 2007
Vehicle: 05 ML500
Mercon V
thanks for the info.
*changed engine oil.
*changed mobile1 gear oil for the diffs.
*changed atf and filter brought from MB.
*brought Mobile1 atf MERCON V for tansfer case.
my question is MERCON V good for the transfer case.
or do I need to stay with DexronIII?
I was told the MERCON V is better than the Dexron.
thanks,
got8
got8 is offline   Reply With Quote
Old 12-29-2007, 06:50 AM   #68 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
thanks,
got8
It should be more than acceptable.
Be careful about reading health books. You may die of a misprint.- Mark Twain
cmitch is offline   Reply With Quote
Old 12-29-2007, 06:56 AM   #69 (permalink)
mortinson's Avatar
Hello again,
Finally changed the transfer case fluid as well as both front and rear diff's (as a preventative measure, I had no nasty noises but that's something I regularly do to my G-Wagens).
Apart from the tips already given I have the following:
1) Aid your effort with a generous bar when undoing the fill/drain plugs. It's amazing how little effort is required to undo them if you can produce the necessary torque.
2) To fill the diffs or the transfer case with fluid, I have used a fluid pump made by SAMOA. It is so good that it can even be used as a syringe, absorbing the fluid directly from the container and injecting it into the diffs or transfer case. www.samoaindustrial.com
3) If you want to prevent leaks from your diffs after the fluid change, you will have to replace the rubber gaskets of the fill and drain plugs of each diff. You'll need four A 025 997 42 48 fro your friendly MB dealer.
4) I always take my Gs for a spin before changing oils and fluids and let them drain generously while I have a cup of tea... this ensures that most of the old fluid has been drained so that you optimize the fluid change.
5) Finally, think about the environment and dispose of the old fluids properly.....
Old 01-11-2008, 01:18 PM   #70 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
The most important step to keep in mind when replacing the transfer case fluid is to NOT overtighten the screws. If they are overtightened, the transfer case cover will crack and you may need a new transfer case. Don't ask me how I know...... (thankfull I had Starmark Warranty at the time)
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
front, rear differentials and transfer case fluid changed busoptr W163 M-Class 0 02-27-2007 10:32 PM
Transfer case and differential fluid change questions Michael Pillay W163 M-Class 14 06-02-2006 10:07 AM
Transmission/transfer case/diff fluid change? anyone have this done? MLnoob W163 M-Class 4 10-04-2004 09:37 PM
Transmission & Transfer Case Fluid Changed roadsession W163 M-Class 15 10-04-2004 08:10 AM
transfer case fluid... why mt-90 instead of 75w-90 ewalberg G-Class 11 08-07-2004 07:16 PM
