» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 03-29-2007, 05:15 AM   #21 (permalink)
Mercedes Benz of Florida
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Great Post! The reaction from everyone was positive.
Keep 'em coming! DIY'ers!
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 04-03-2007, 02:47 PM   #22 (permalink)
fkong777
fkong777's Avatar
Date registered: Nov 2004
Vehicle: 02 S430 - 00 ML55 - 91 NSX
Send a message via Yahoo to fkong777
its only a little over 1 qt. so you can use a small hand pump the screw right on top of your qt bottle. give it a good few pump and it will over flow. I had to double check on the filler hole since it is only about 1 inch higher fluid level wise than the drain plug.
fkong777 is offline   Reply With Quote
Old 04-09-2007, 10:53 AM   #23 (permalink)
laxman0324
laxman0324's Avatar
Date registered: Nov 2005
Vehicle: 1997 Nissan Pathfinder SE
Send a message via AIM to laxman0324
you can buy a little pump that you attach to your drill and one end of the tube goes in the bottle and the other end goes in the transfer case...works very well with no mess and is very quick
laxman0324 is online now   Reply With Quote
Old 04-16-2007, 07:52 AM   #24 (permalink)
PUPU
Date registered: Nov 2006
Transfer case Job
I just like to make it sure for us. Could we use all these fluids for tranfer case.
AUTOMATIC TRANSMISSION FLUID
(See your MB center regarding application. Do not use in 722.6 or 722.9 transmission!)
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257 / 22096
Chevron ATF Dexron III F-30108 / 30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron-III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Pennzoil, ATF D-21380
Pennzoil, ATF F-30110
Quaker State Dexron-III/Mercon F-30161
Sunoco ATF Dexron-III/Mercon F-30176
Texaco ATF Mercon/Dexron-III F-30321
Unocal Multi-Purpose ATF D-22413 / 22431
Valvoline ATF Type D
Supplier Information:
Castrol, Piscataway, NJ / Toronto, Canada
Chevron Products Co., San Francisco CA
Citgo Petroleum Corp., Tulsa, OK
Exxon Company USA, Houston, TX
Texaco Lubricants Co., Houston, TX
Pennzoil Products Co., Houston, TX
Quaker State, Seneca, PA
Sun Co., Philadelphia, PA
Unocal Science and Technology Div., Brea, CA
PUPU is offline   Reply With Quote
Old 04-17-2007, 03:05 PM   #25 (permalink)
fkong777
fkong777's Avatar
Transfer case - Yes. Dexron 2 or 3 type ATF. But dont use those for the trannsmission. Use only MB ATF
Old 04-18-2007, 12:50 PM   #26 (permalink)
Dim(A)
Dim(A)'s Avatar
Date registered: Dec 2004
Vehicle: 2002 (MY2003) ML350
What is the MB ATF part number for w163 transfer case? Here in Russia some dealers use 001 989 21 03 10 (MB 236.10) - the same as for transmission.
Dim(A) is offline   Reply With Quote
Old 04-18-2007, 11:29 PM   #27 (permalink)
busoptr
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
Do you think MB misprinted the fluid to use for the transfer case because I used dexron3 and synthetic dexron 3 and still I get the noise. At the MB stealership they say use mb fluid type a6 or something like that.
busoptr is online now   Reply With Quote
Old 04-19-2007, 12:31 PM   #28 (permalink)
cmitch
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
Mine took three changes to totally eliminate the noise, though it got extremely quieter after the first change. If your transfer case is damaged, then the noise will never go away.
Be careful about reading health books. You may die of a misprint.- Mark Twain
cmitch is offline   Reply With Quote
Old 04-23-2007, 03:17 PM   #29 (permalink)
zaphodsplanet
zaphodsplanet's Avatar
Date registered: Jun 2005
Vehicle: 04 E320
Send a message via Yahoo to zaphodsplanet
Just out of curiosity.... what does the crank case noise sound like? I've got a funny noise but I think it has to do with the brakes. I recently put on new rotors and pads and the noise totally disappeared... but now it's back. So.... this is just a curious question..
Z
P.S.... you're right... Windows TOTALLY SUCKS.... Mac OSX Rules.....!!!..LOL
Newly on Benz #6
Finally traded 00 ML (miss it though)
zaphodsplanet is offline   Reply With Quote
Old 04-23-2007, 11:10 PM   #30 (permalink)
busoptr
busoptr's Avatar
Z
The noise is like when youre a kid and you put a popsicle stick on your bike's wheels and it hits the spokes to make the sound. It sounds like that. And I hate it on my ML.
front, rear differentials and transfer case fluid changed busoptr W163 M-Class 0 02-27-2007 10:32 PM
Transfer case and differential fluid change questions Michael Pillay W163 M-Class 14 06-02-2006 10:07 AM
Transmission/transfer case/diff fluid change? anyone have this done? MLnoob W163 M-Class 4 10-04-2004 09:37 PM
Transmission & Transfer Case Fluid Changed roadsession W163 M-Class 15 10-04-2004 08:10 AM
transfer case fluid... why mt-90 instead of 75w-90 ewalberg G-Class 11 08-07-2004 07:16 PM
