» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 03-23-2007, 02:27 PM   #11 (permalink)
sgaar
Date registered: Jun 2006
Vehicle: '06 W211.070, '99 W163.172 & '87 R107.048
I had that creaking noise on my '99 right up until this afternoon. I changed the oil, drove about 1/4 mile and it was greatly reduced. This is great
The noise is still there but you have to pay attention to hear it so I'll just wait about 1200-1500 miles and change it again.
All in all it took about 20 minutes with a pump I got from Autozone. The pump and Dexron III was about $16. This is a steal!
sgaar is offline   Reply With Quote
Old 03-23-2007, 03:44 PM   #12 (permalink)
MillTek
Date registered: Aug 2003
Vehicle: ML430
OK. Just finished changing the transfer case fluid. Here's the method I used to get the new Dexron III into the case;
I bought around 5 feet of 5/16 inch clear plastic tubing from a local auto store. Then I shoved a funnel (really hard) down into it. I lay under the car and held the end of the tube into the fill hole on the case and my wife poured the fluid into the funnel as she stood beside the car. Basically, as advised elsewhere, we filled until it overflowed. Then I just re-installed the plug and the job was done.
Now, let's hope that the infernal clicking goes away in the next few hundred miles!!!
Jim
MillTek is offline   Reply With Quote
Old 03-23-2007, 05:50 PM   #13 (permalink)
sgaar
Jim
Well that will work too.
I took a look at the oil I drained and it looks like there i very fine sand in it. If that is the case I guess that it is coming from the road and that maybe the seal is not in as good a shape as they should be.
Also, if it sand I beleive that it should be just as good to change the oil tomorrow again. It is a matter of getting the sand flushed out and the sooner it is done the better. With about $4 per quart for the Dexron I would rather do it a couple of times instead of waiting 1200-1500 miles.
Old 03-25-2007, 12:26 AM   #14 (permalink)
busoptr
busoptr's Avatar
Date registered: Oct 2006
Vehicle: 2000 ml430, 2007 lexus ls
good job
busoptr is online now   Reply With Quote
Old 03-25-2007, 11:20 AM   #15 (permalink)
onesixthree
Date registered: Sep 2003
Vehicle: '02ML320
Hmm. That does not sound good. I don't know how sand will get in there?
onesixthree is offline   Reply With Quote
Old 03-25-2007, 03:50 PM   #16 (permalink)
sgaar
I don't know either. The thing is that the looked and felt very uniform in size and color. Much like sand from the beach but I don't know how it got in the transfer case. I will try to flush it an extra few times and see if I can get the rest out.
If not I might have to take the case off and get it flushed out.
Old 03-25-2007, 07:41 PM   #17 (permalink)
mcphere
Date registered: Feb 2006
Vehicle: 2002 ML 500
What do you guys think about this plug?
Engine Oil Drain Valve
:-) mcphere
mcphere is offline   Reply With Quote
Old 03-25-2007, 11:16 PM   #18 (permalink)
busoptr
busoptr's Avatar
I think it will be great for changing engine oil
Originally Posted by mcphere
Looks good for the engine oil pan drain bolt
Old 03-26-2007, 09:27 AM   #19 (permalink)
Qzyn
Qzyn's Avatar
Date registered: Aug 2006
Vehicle: Mercedes ML 320 '98 and Yamaha Fazer FZ6S '04
HI!!
nice gadget and looks cool,
finally no problems in guessing which one of the drain bolts is for engine oil
No "Star", no fun!!!
Qzyn is offline   Reply With Quote
Old 03-28-2007, 11:50 PM   #20 (permalink)
DETANE
DETANE's Avatar
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
This Is The Best Post I Have Seen A While. Im Doing My Ml430 Next Week For Sure.
"LIFE IS SHORT, LIVE IT WELL"
DETANEone
DETANE is offline   Reply With Quote
front, rear differentials and transfer case fluid changed busoptr W163 M-Class 0 02-27-2007 10:32 PM
Transfer case and differential fluid change questions Michael Pillay W163 M-Class 14 06-02-2006 10:07 AM
Transmission/transfer case/diff fluid change? anyone have this done? MLnoob W163 M-Class 4 10-04-2004 09:37 PM
Transmission & Transfer Case Fluid Changed roadsession W163 M-Class 15 10-04-2004 08:10 AM
transfer case fluid... why mt-90 instead of 75w-90 ewalberg G-Class 11 08-07-2004 07:16 PM
