How to replace the drive-shaft center (support) bearing ML320, 2002? - Page 2 - Mercedes-Benz Forum
post #11 of 37 (permalink) Old 03-23-2010, 10:22 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 882 Post(s)
Originally Posted by imwalkin View Post
I had it done by a friend who is a mechanic and works on MBs... I think he put in a poor quality part... I'm still not sure untill I crack it open....
do you know of an HD bearing for this application? I have seen a few car part sites claiming a HD bearing... just curious
There is only one support bearing. I have never heard of a HD version. My only suggestion to you is purchase the kit from M/B (163 410 00 10). If you are doing it yourself make sure you mark everything .
43sqd is offline
post #12 of 37 (permalink) Old 03-24-2010, 02:57 AM
Date registered: Aug 2004
will do...most people advise putting the truck on all four jack stands...is that for clearance of the axle during removal/install or do the wheels need to be free to rotate... just curious
imwalkin is offline
post #13 of 37 (permalink) Old 03-24-2010, 05:11 AM
Quoted: 882 Post(s)
More for clearance than anything else. If you mark the flanges on either end of the drive shaft then it should go back with no problem.
43sqd is offline
post #14 of 37 (permalink) Old 03-24-2010, 08:04 AM
benz_al's Avatar
Date registered: Aug 2007
Vehicle: 1998 ML320
Quoted: 4 Post(s)
In case you find hard to unbolt the mounting screws/bolts as #3 in the OP and #47 in 43sqd's diagram, a little heat will help. I used a small propane torch from below for a few seconds and made unbolting really easy. Just be careful not to overheat and protect any wires in the area.
98 Ml320, can't find anything wrong anymore!
benz_al is offline
post #15 of 37 (permalink) Old 03-24-2010, 10:06 AM
Good Tip!!! It did come off a year ago when I had it replaced ..so I'm hoping it will come off with ease....saturday will be the big day.. I'll post results...
thank you for all your help and input! unlike other forumns people on here are helpful.
imwalkin is offline
post #16 of 37 (permalink) Old 04-01-2010, 08:03 AM
Date registered: Jul 2008
Vehicle: 2001 ML430 / 2010 ML350 Bluetech
Quoted: 8 Post(s)
Is there a specific procedure to line the drive shaft up after reinstallation, there is a fair amount of play in the holes. I have replaced many center bearings on other vehicles, and last year on my ML, now it seams I will have to replace again, as its starting to make noise, so as its only a year old, I wonder if there was a problem with my installation....
clowrym is offline
post #17 of 37 (permalink) Old 04-01-2010, 08:20 AM
Quoted: 882 Post(s)
Mark the flanges on either end of the drive shaft before removal, then draw a center line on the drive shaft once it's off as per the instructions.
43sqd is offline
post #18 of 37 (permalink) Old 04-06-2010, 01:20 AM
Date registered: Apr 2007
Vehicle: 2003 ML320, 1981 16v VW Truck
I just did this procedure tonight and it wasn't all that bad. They were right though about those 2 bolts that hold on the center support, but after shooting a Mapp gas flame up into the holes from underneath they came out extremely easily!
Good luck to everyone else that tries the removal.
elomont is offline
post #19 of 37 (permalink) Old 10-05-2010, 10:52 AM
Date registered: Jan 2010
Vehicle: 1999 ML320
Quoted: 2 Post(s)
I am shopping around for this drive shaft centre support and there are different brands on the market.
Can someone help based on their experience for the best from the following:
1-Hamburg Tech $90
2-NSK Bearing $90
3-APA/URO $90
4-Febi Bilstein $160
Thanks
Astani is offline
post #20 of 37 (permalink) Old 10-05-2010, 08:55 PM
Date registered: Jun 2009
Vehicle: 03 ML350
So the question is why did MB put an extra joint in this shaft thus requiring a center bearing? Seems pointless to me.
benzml350 is offline
    Replace Drive Shaft Support also when replacing bearing ? pcy W163 M-Class 10 02-20-2008 03:22 PM
    1998 ml320 drive shaft support????HELP!!!!! jroque97 W163 M-Class 12 08-12-2007 11:02 PM
    How to replace the driveshaft center (support) bearing ML 320 Smith007 W163 M-Class 0 03-12-2007 01:55 PM
    PLEASE: How to replace driveshaft support (carrier) bearing ML 320 2002 Smith007 W163 M-Class 0 03-11-2007 09:56 PM
    Center support bearing broken on 300D rhuprect W123 E,CE,D,CD,TD,TE Class 3 04-14-2005 06:01 PM
