» Site Navigation » Other Sites
03-21-2007, 09:42 AM
#11 (permalink )
Date registered: Nov 2005
Vehicle: 2001 ML 430 - Silver
Looks like oil is still leaking, a very small amount on the silver engine housing, but not coming from the cap. Kajtek - have more details?
04-21-2007, 07:04 AM
#12 (permalink )
I'm off to pick up the rest of the parts needed for the oil filler area - there are four parts total:
- Oil filler cap
- Top Gasket (comes with the filler cap, installed in it)
- Neck
- Bottom gasket
Picking up the neck ($16) and bottom gasket ($5) today from my local dealer, will try to install later when things cool down.
01-11-2008, 04:14 PM
#13 (permalink )
Date registered: Aug 2007
Vehicle: 1993 280E,RHD
So...wjbarton,what happened next?
No more leaks since you replaced an oil filler cap?
Now I have the same problem after 140Ks with my M104 engine.
02-02-2008, 12:37 PM
#14 (permalink )
No, I still see a little leak after all of that. The same leak. It's very, very small, and I haven't had any oil amount problems, so I've put that one aside for now. I'll look back into it after I get some other things squared away though, cheers!
02-02-2008, 10:10 PM
#15 (permalink )
Vehicle: E300DT/320cdi ML320/55
More about breathing pipes. In CA dry weather never had the issue, but remember long time ago, while living in 4-seasons the moisture mixed with oil on colder engine and accumulate on flame retarding screens in the breathing tubes. With the breathing tubes clogged the crankcase pressure had to lift the cap and escape there.
I never had to get to breather tubes on ML, but they usually go from top of the engine to air filter housing.
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Repair Costs for very slight oil leak at phenolic (sic) oil filler cap, 2001, 320 noelchambers R170 SLK Class 2 11-05-2005 07:53 AM Oil Filler Cap Leak That Won't Stop.... brianzero W123 E,CE,D,CD,TD,TE Class 12 07-28-2005 07:28 PM Leaking Oil from Oil Filler Cap Stickman W124 E,CE,D,TD Class 1 06-05-2005 08:42 AM Oil Filler Cap ychachad W140 S-Class 1 08-04-2004 08:32 PM 500E oil leak from filler cap Guest (MBNZ) W124 E,CE,D,TD Class 0 08-16-2001 08:29 AM
