Power steering reservoir O-ring - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 02-12-2007, 01:24 PM Thread Starter
Jexpert's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML500
Send a message via MSN to Jexpert
Hi all,
Anyone got the part no. for the famous O-ring between the reservoir and the power steering pump?
THX
2002 ML500 Desert Silver
10x20" Kahn rims
295/40/20 TOYO PROXES S/T tires
Webasto Telestart T100 HTM
K&N Air Filter Element
Jexpert is offline
post #2 of 25 (permalink) Old 02-12-2007, 04:36 PM
Date registered: Apr 2005
Vehicle: 1999, ML430
I've been contemplating doing this too. Somewhere along the way I was told the part number is 000 466 18 80.
I'd appreciate hearing your progress and process for this repair. Good luck.
jamesvyu is offline
post #3 of 25 (permalink) Old 02-13-2007, 10:24 AM
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 223 Post(s)
That O-ring is less that $5.00 from the dealer. R&R would be about 30 minutes. I used a turkey baster to remove the fluid from the reservoir, undo 2 retaining bolts ( if I remenber correctly), remove hose, pull the reservoir forward, clean reservoir and R&R O-ring. Then reverse the process. Cleaning took most of the time doing this procedure.
edcarls is offline
post #4 of 25 (permalink) Old 02-13-2007, 10:37 AM Thread Starter
Jexpert's Avatar
Vehicle: 2002 ML500
Yes, it's the right part no. I just ordered one and also ordered a new reservoir.
Reservoir part no. is: 000 460 0183
10x20" Kahn rims
Jexpert is offline
post #5 of 25 (permalink) Old 02-03-2008, 08:55 AM
Date registered: Dec 2006
Thanks for the information; I will order these from the Dealer
cnwakobi is offline
post #6 of 25 (permalink) Old 02-03-2008, 12:58 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Do the new ML's use the same POS power steering system? My 06 ML350 just had power steering warranty repair done at 38K miles (leaking reservoir).
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #7 of 25 (permalink) Old 02-03-2008, 01:40 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 131 Post(s)
What I have found..
I don't know about the W164 steering compared to the W163 steering, sorry.
On the "o-ring" replacemewnt - most DIY's also chose to order a new "c-ring" which is a steel clip ring which holds the reservoir. First, good to have a spare c-ring in case you drop the original during removal. 2nd, most expereince3d MB mechanics replace the c-ring since the stampled steeel part will lose some of its original holiding strength with a couple of removals.
Also , you will need MB "power steering oil" (about USD$9 per qt) to top off after replacement. Takes about .75 of a qt, most people buy 2 qts to have some in the garage. Best to use original MB p/s/ oil as not to mix different typer fluids in the power steering system.
If you are also replacing the reservoir, you can use the color caps from the new reservoir to cap off the old fittings on the old reservoir to help keep the mess factor down.
Keep the beat !
fabbrisd1 is offline
post #8 of 25 (permalink) Old 02-04-2008, 06:39 AM
geordie's Avatar
Vehicle: 2002 SLK32AMG,1995 E320 Cab 1990 300CE(Gone).2002 ML320 (Gone)
Quoted: 15 Post(s)
Removing the C ring
I found the easiest way to remove the C ring was with a small hook.
Just slide the hook into the ring on the side nearest the left fender and pull straight towards the fender.
Geordie
VA USA
2002 SLK32///AMG
1995 E320 Cabriolet
geordie is offline
post #9 of 25 (permalink) Old 02-04-2008, 06:57 AM
benzfixer's Avatar
Vehicle: Don't own a Mercedes, probably because I fix them for a living. LOL.
Guys, also check the power steering fluid cooler hoses on the side of the radiator on the drivers side.
Usually one or both of them have walked outward and can pop off any time causing you to lose all the fluid at once.
Simply pushing the hose back on flush and tightening the clamp will do, but sometimes the hose itself is deteriorated and all "gummy".
In this case, I usually cut a bit of the bad portion off and reattach.
Do not cut too much off because there is not alot of length to work with.
Sometimes the cooler portion of the radiator plugs up and causes the hoses to pop off regularly.
Some techs can gently blow compressed air into the coolers from inlet to outlet and blow a slurry of debris out, but it is not recommended.
I have also seen some where the cooler ports on the radiator are purposely blocked off, and an auxillary p/s cooler is installed.
benzfixer is offline
post #10 of 25 (permalink) Old 10-30-2008, 04:48 PM
Date registered: Oct 2008
Vehicle: '03 ML320
Would someone please tell me what the tool you used to remove that "retainer bolt" (1) that attaches the reservoir to the pump? I can't find the tool that matches the weird-looking bolt on it. Mine is 2003 ML320. Thank you!!!
bkmyway is offline
    ml-320 power steering fluid reservoir saltof W163 M-Class 5 12-18-2007 07:43 AM
    power steering pump reservoir perdidojoe W163 M-Class 2 02-05-2007 04:02 PM
    Unidentified objects in the power steering fluid reservoir -- what are they? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 4 04-23-2006 04:05 PM
    Power steering reservoir tobyd W124 E,CE,D,TD Class 4 01-31-2006 10:17 AM
    Uh oh. Put power steering fluid in hydraulic reservoir! C + A W140 S-Class 7 08-24-2005 04:53 PM
