Old 02-02-2007, 09:36 PM   #1 (permalink)
Benz_Boi's Avatar
Date registered: Feb 2007
Vehicle: 2001 Ml 430 Sport
Send a message via Yahoo to Benz_Boi
Inside terrible tire wear..
I have a 2001 ML 430. I recently noticed my steering being off-center, and after looking under my truck at the front tires I see that they have prematurely wore on the INSIDES. The outsides of the front tires have perfect tread left, but the insides are almost bald.
Well, I had a 4-wheel alignment done, but my steering is still off-center. Im concerned because when I replace these expensive tires, I dont wanna wear out the 2 new fronts again.
Does anyone think the wheel allignment should have fixed the problem?
Once I replace the 2 bald tires should my steering no longer be crooked?
Thanks!
- VIC
She loves me, She loves me not...
Benz_Boi is offline   Reply With Quote
Old 02-02-2007, 10:12 PM   #2 (permalink)
Date registered: Apr 2006
Vehicle: 2005 ML500SE
Thanks!
- VIC
Alignment should have fixed it. I suspect the toe-in measurement was off to start
with, being toed out would wear the front tires on the inside. Take it to a
reputable alignment shop. Have them lock the steeering wheel straight and then
shorten one tierod and lenghten the other while maintaining overall correct toe
spec. That will correct the problem!!
134 MPH is 195 feet per second. Not a smart thing to do in the rain!!!
Panzer Man is offline   Reply With Quote
Old 02-03-2007, 07:45 AM   #3 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
Thanks!
- VIC
I think it's required(or suggested) that if we replace any tire, we should replace all 4 because of the ESP system. That's what I was told last week.
asianml is offline   Reply With Quote
Old 02-03-2007, 07:51 AM   #4 (permalink)
MJ50's Avatar
Date registered: Nov 2003
Vehicle: C240 & ML350
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
was ur car lowered??
2003 C240 heavily modded
2004 E55 stock
2004 ML350 sold
MJ50 is offline   Reply With Quote
Old 02-03-2007, 03:52 PM   #5 (permalink)
Benz_Boi's Avatar
NOPE... My truck has not been lowered. I already had the 4-wheels alligned about a week ago, but I am concerned that I am gonna ruin a set of new tires once I put them on. If I buy a set of new tires, and ride a few months and notice they are worn on the insides again, Im gonna be pissed at wasting all that money of the tires.
I commute to work in my truck, and drive about 95 miles everyday round trip. Until I buy another car in a few weeks, this is my daily driver. By the way, this Benz is super quick and a blast on the freeway! I have only had it 3 months and have put about 8000 miles on it already!!! Im getting a Trans Am soon, so maybe then it can rest in the garage more...
- VIC
Old 02-03-2007, 04:38 PM   #6 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
- VIC
are you sure your tires werent already like this before your alignment. unless you alignment is severly out, i dont see tires haveing severe wear after 1 week of getting an alignment
Streetglower is offline   Reply With Quote
Old 02-03-2007, 04:40 PM   #7 (permalink)
its usually recommended to replace tires in sets, 2 front or 2 rear. and getting an alignment with a tire purchase.
Old 02-03-2007, 04:48 PM   #8 (permalink)
Benz_Boi's Avatar
Yes.. Im almost positive they were like this before the allignment. Im gonna replace the 2 front, and hope the allignment fixed the problem. I really enjoy the OEM Dunlop Sports. They are the best tire I have ever driven on in the rain, but just average in the snow...
Old 02-03-2007, 06:24 PM   #9 (permalink)
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430
Correct me if I'm wrong... but isn't there a difference between a 4 wheel alignment and a front end alignment? I've had two 4 wheel alignments and my steering is still off center, which is why both my mechanic and Costco recommended I get a front end alignment.
2000 ML430
Chrome grille, tailgate latch, logo on rims, instrument cluster rings - K&N air filter - Ate brakes - projector style lights w/xenon bulbs - white LED lights on licence plate - handpainted pinstripe - designo Java Shift Surround
NEW! Click to read the New Members Guide
bocabenz is offline   Reply With Quote
Old 02-03-2007, 07:02 PM   #10 (permalink)
Yes, there is a difference between 2 wheel and 4 wheel alignment. However your caster camber and toe can all be within spec, but the steering wheel can be crooked. What happens is that the toe was set to spec with the steering wheel crooked. A good alignment shop will lock the steering wheel straight BEFORE they set the toe. See my post to Benz_Boi! I did alignments for GM dealers in my younger days, and the biggest complaint was crooked steering wheels. I always took the time to set it straight and test drive it to insure it was correct. Today people are getting lazy with the lasers. The basics are still the same-----hope this helps!
inside rear tire wear IAR W126 S,SE,SEC,SEL,SD,SDL Class 5 05-09-2006 07:37 PM
Tire wear? Steve230 R170 SLK Class 1 08-29-2004 06:55 PM
Tire wear rdsw W126 S,SE,SEC,SEL,SD,SDL Class 1 06-28-2004 07:14 PM
Severe wear on inside of both front tires. Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 4 09-18-2002 11:30 PM
HELP... Rear inside tire wear..Is this a camber issue????? Peter - San Francisc R170 SLK Class 18 06-16-2002 10:57 AM
