Cel - P0456 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-06-2007, 11:02 AM Thread Starter
MJ50's Avatar
Date registered: Nov 2003
Vehicle: W204 & W211
Quoted: 17 Post(s)
Question Cel - P0456
I got CEL a few days ago.
Bought OBDII scanner and got following message
P0456 - EVAP Evaporation Control System Leak Very Small
I have service due in 3k miles.
Is this something I can wait that long or should I take it to dealer asap to get it fixed? The car runs same as before btw.
W211 | W204 | W163 | W203
MJ50 is offline
post #2 of 9 (permalink) Old 01-06-2007, 07:33 PM
Vehicle: Black 2005 ML 500
Cel - P0456
Are you sure your gas cap is closed all the way in..? The cel light will turn on if the gas cap seal has a leak or if it is not closed all the way..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Yokohama Geolander HTS + Bi-Xenons(+ Drew's e-code mod, though the reflectors rusted off and do not give out much light anymore), Yakima roof bars, Akebono pads all around. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After all these years of owning my current 2005 ML 500, it is a major unreliable vehicle with a very large/expensive repair/defect history and has been like this since brand new.
AC_ML is offline
post #3 of 9 (permalink) Old 01-06-2007, 10:47 PM Thread Starter
MJ50's Avatar
Quoted: 17 Post(s)
yeah, i put gas today and double checked the gas cap...
it's sealed until u clear click... (unless cap itself has some leak???)
MJ50 is offline
post #4 of 9 (permalink) Old 01-07-2007, 09:13 AM
Cel - P0456
Did you reset the CEL light, with your OBDII, to see if it will come up again..? On other vehicles, too, any disconnected/broken vaccum hoses will cause similar problems.. You may want to check your engine area hoses/connections just in case..
Or since you have only 3000 miles for service, they can hook it to the computer for a more detailed diagnostic. Unluckily our simpler OBDII's features (I have an ACTRON CP9145 scanner) are still not complete enough in many diagnostic/trouble shooting areas.
AC
2005 ML 500
AC_ML is offline
post #5 of 9 (permalink) Old 01-07-2007, 09:17 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 210 Post(s)
Remove your engine cover and look at the left side for an aluminum tube that comes from the back of the engine and ends with a plastic cap towards the front. Make sure the plastic cap hasn't come loose. If this cap is loose, it will throw this code (happened to me a month ago).
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is online now
post #6 of 9 (permalink) Old 01-08-2007, 12:58 AM Thread Starter
MJ50's Avatar
Quoted: 17 Post(s)
ok, i'll take a look.
MJ50 is offline
post #7 of 9 (permalink) Old 01-08-2007, 02:52 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
usually the common causes are the purge valve or the canister. I have seen a few leaky fuel tanks cause the issue. I just recently put a purge valve in a ML500 for the same code. Wee different code but same thing.
Streetglower is offline
post #8 of 9 (permalink) Old 01-14-2007, 11:11 AM Thread Starter
MJ50's Avatar
Quoted: 17 Post(s)
i removed the scanner and CEL is turned off for the last several days.... hope it will stay that way...
MJ50 is offline
post #9 of 9 (permalink) Old 01-14-2007, 12:02 PM
Quoted: 4 Post(s)
with evap leak codes, whether a big or small leak, it wont come right back. those kinds of codes take several drive cycles before it will return. it may return in a week, maybe 6 months depending on if you met the drive cylce.
    Cel penbed51 R170 SLK-Class 9 12-27-2006 04:25 PM
    Has your CEL just...... gsj224 W163 M-Class 1 05-17-2006 08:57 AM
    CEL YOGGI W202 C-Class 9 04-03-2006 05:25 AM
    Why I like my CEL Check Codes General Mercedes-Benz 5 03-06-2006 09:59 AM
    Ok, my CEL came on ... JimB W163 M-Class 4 11-17-2005 08:29 PM
