» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 12-12-2006, 04:13 PM   #1 (permalink)
Oatie44's Avatar
Vehicle: The ML 320
Send a message via AIM to Oatie44
Changed flat tire and car won't move
I got a flat tire coming home from school today and didn't notice until I got home. I changed the tire in my garage and now the car won't move even in reverse or drive. How does this happen and what did I do wrong? Aswell my wheel is slightly bent. Is there any way to repair the wheel? I appreciate any help from the benz world community.
Oatie44 is offline   Reply With Quote
Old 12-12-2006, 05:00 PM   #2 (permalink)
Oatie44's Avatar
Vehicle: The ML 320
Maybe my parking break is broken???
Old 12-12-2006, 05:46 PM   #3 (permalink)
Date registered: Nov 2006
Vehicle: 2003 SLK32 AMG
Red face that would be the BRAKES!
did you set your parking BRAKE before it BROKE and became breaked? my brake will barely hold the car stationary and i just replaced the shoes in the system....I cant imagine a parking brake that could lock your car up especially if you backed it up did you try reverse as well as forward?...
n5151ts is offline   Reply With Quote
Old 12-12-2006, 05:56 PM   #4 (permalink)
tsanjose's Avatar
Vehicle: 2000 ML430
Send a message via ICQ to tsanjose Send a message via AIM to tsanjose Send a message via Yahoo to tsanjose
did you change your tires or the wheel itself? maybe your lugs/bolts are too long for the replacement wheel?
tsanjose is offline   Reply With Quote
Old 12-12-2006, 06:50 PM   #5 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320 Depo/E55bix, clear fogs, E55 rims/tails/seats, Audio10, BilsteinSport, cut springs
zactly! you should have had shorter bolts for use with spare rim. the sare is usually
lighter and have less cross section in material in the lug area. the longer ones are
sticking out back and hitting something....brake caliper ¿ !
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 12-12-2006, 07:04 PM   #6 (permalink)
Bogie's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
Sh$t! You didn't damage your rotor did you?
Bogie
Bogie is offline   Reply With Quote
Old 12-12-2006, 07:05 PM   #7 (permalink)
Smile really? wow I learn something new every day about my ML55 thanks!
Old 12-12-2006, 07:41 PM   #8 (permalink)
DrX
DrX's Avatar
Vehicle: 2002 ML320
Oatie44, you need to find the lug bolts that attached the original wheels. Replace those then you should be able to move your ML. Order a new wheel to replace your bent one. After all, owning an MB is about safety, right?
DrX is offline   Reply With Quote
Old 12-12-2006, 08:38 PM   #9 (permalink)
Darkmann's Avatar
Vehicle: Anything w/Wheels
I suspect that the rim you replaced was not OEM. If the rim is not the same size as OEM, find the OEM lugs (or equivalent) and use with the spare. I think that the lugs you're using are too long and are interfering with the rotors.
1989 300ZXT - mine
A pair of running shoes
A 18Hp lawn mower
2 Mountain Bikes
350Z - will be mine when @ 300+HP and 3-Car Garage
Darkmann is offline   Reply With Quote
Old 12-12-2006, 09:16 PM   #10 (permalink)
Vehicle: 98ML320
There are many companies that can repair your rim just do a google for "fix wheel" or "repair rim" and you'll find tons.
Here's one random one.
http://www.fixrim.com/
bigcatny is offline   Reply With Quote
Car Won't Move! bowen240 W123 E,CE,D,CD,TD,TE Class 3 11-06-2006 11:13 AM
Got a flat tire and.. uptown W163 M-Class 6 09-12-2006 12:04 PM
Flat tire Curiosity ponzese R171 SLK Class 3 09-14-2005 11:55 AM
Flat tire! Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 3 07-16-2004 07:03 AM
WARNING! Tire Minder gave me a flat tire. (And almost a second). HEX20 R170 SLK Class 8 09-19-2003 11:52 AM
