2 problems with 2002 ml500 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 12-08-2006, 04:18 PM   #1 (permalink)
Date registered: Dec 2006
hey guys, have a 2002 ML500 in excellent condition with 70k. i have noticed 2 things lately. 1. it looks like its slightly leaking from bottom of radiator (passenger side) by where the hose/ clamps goes into radiator. is thier any issues known on that hose/clamp?
2. when i am at a complete stop and take off with force, i feel a shift underneath the car somehwere from the middle to rear of car. its only if i step on it. it does not happen if I take off slowly. it also does not happen if I am already moving and then suddenly hit gas. ANy ideas?
Thanx alot guys, forum is great!
corvetteZ06 is offline   Reply With Quote
Old 12-08-2006, 04:39 PM   #2 (permalink)
Vehicle: ML550, W212 E350 4 matic, 1966 Corvette C2 convt.
Of course check the hose and the hose clamps. Thats the first thing to look at. As for the "shift", sounds like someting is sliding around, check under the seats and in the side storage areas in the cargo area and in the door pockets. Also be certain your spare tire is in the rack correctly.
sosh is offline   Reply With Quote
Old 12-08-2006, 10:08 PM   #3 (permalink)
hey, thanx for the reply. but its def. outside of the truck, maybe the driveshaft? or torsion bar? has anyone had anything similar?
2006 F350 SD
2003 BMW 325 CIC
2002 ML500
2001 Jeep Gd Cherokee Limited
2001 Corvette convertible
1999 CLK320 convertible
Old 12-09-2006, 02:57 AM   #4 (permalink)
ml28's Avatar
Vehicle: ML500
When my driver's side motor mount was bad on my 2002 ML500, I felt motion at the gear selector when accelerating from a stop. It felt like the whole engine/transmission assembly was shifting front to back. Since the driver's side motor mount was changed, I can report that there are no more issues with the gear shifter and the engine feeling like it's shifting around. The rubber on the old motor mount was completely ripped - only the safety bolt was preventing the mount from pulling apart. Hope this helps!
-02 Black ML500 w/ Sport Package
Bilstein shocks, H&R rear springs, Toyo Proxes ST tires
-98 Polar White ML320 - totaled (rear-ended by drunk driver)
Bilstein shocks, H&R rear springs, monochrome paint scheme like MY2000+ ML's, ML430 wheels w/ Falken 275-60-17 S/TZ-01 tires, MY2002+ halogen headlights
ml28 is offline   Reply With Quote
Old 12-09-2006, 07:32 PM   #5 (permalink)
Mac
The transfer case is in that location, although if there was something going wrong with it, I think you'd probably see a red light blink on the dash.
Mac is offline   Reply With Quote
Old 12-09-2006, 08:11 PM   #6 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/300DT
The hoses under the clamps "memorize" the shape over the years and might not offer enough pressure to hold the seal. It is good idea to go thru all clamps every couple of years. Our 99 model had small leak on transmission fluid cooling hoses.
To my knowledge those cars have lot of controlling sensor on the engine, but none on transfer case, or differentials.
Never hurts to raise the car and take a good look under.
Kajtek1 is online now   Reply With Quote
Bookmarks
2002 Ml500 astro209 W163 M-Class 5 06-06-2006 11:26 PM
2002 ML500 Karen W163 M-Class 20 03-15-2006 10:25 PM
2002 ML500 US to Europe GertT W163 M-Class 13 04-09-2005 05:06 AM
No tunes in my 2002 ML500 BLACKML Audio & Telematics Forum 1 02-20-2005 04:18 PM
Vav for 2002 ML500 mdane W163 M-Class 1 11-30-2004 07:52 AM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
