Check Engine light and code P0170 and P0173 - Mercedes-Benz Forum
post #1 of 69 (permalink) Old 11-19-2006, 09:52 AM Thread Starter
sstomcat's Avatar
Date registered: Jun 2006
Vehicle: ML-55 - 2000,
Quoted: 20 Post(s)
The CEL light came on last nite and I took it to Autozone for reading...Came back with code P0170 and P0173. Guy at Autozone says it could be
Faulty O2 sensors
Mass Airflow Filter
Misfire...
Vehicle drives perfectly without any jerks, idyling or knocking...have about 50 K miles.
Surprisingly while driving back the light goes off, I'm confused please provide your opinions and what should I do. Thanks
AMG 19X9.5 Wheels,
Stock AMG 18X8.5 Wheels
Yokohama Advan S/T 295/45/19 Tires,
Bridgstone Dueller 285/50/18
SCHATZ Chrome Rear hatch handle,
SCHATZ Chrome Headlight Trim
Chrome AMG License Frame,
SCHATZ Chrome Side Light Surrounds,
German Howell Chrome Door Lock Surrounds,
German Howell Chrome Indash Air vent surrounds,
AMG Stem Valve Caps
LED Tail Lights
sstomcat is offline
post #2 of 69 (permalink) Old 11-19-2006, 11:39 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
The codes are for the Mass Air Flow Sensor. It is located between the throttle body and the air filter case. You will see it has a plug in the side. Unplug and remove it by taking the hose clamps off each end. Once you have it out, clean it out with a good throttle body/intake cleaner. Allow it to dry and reinstall. If the light continues to come on, you will need to replace it. Cleaning has worked for some.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 69 (permalink) Old 11-19-2006, 11:56 AM Thread Starter
sstomcat's Avatar
Quoted: 20 Post(s)
thanks for the quick reply.....am I certain that it is the MAF?
AMG 19X9.5 Wheels,
AMG Stem Valve Caps
LED Tail Lights
sstomcat is offline
post #4 of 69 (permalink) Old 11-19-2006, 12:28 PM
Kajtek1's Avatar
Quoted: 1167 Post(s)
MAF from what I researched doesn't have error codes, but bad sensor will trigger several different malfunctions. My son had 10 errors and took it to a dealer, who for $100 tested the MAF bad.
New MAF sells for $129 at our sponsor, so I would rather spend hundred buck on new MAF even not knowing it is bad, than give it to stealer for 5-minute diagnosis.
Kajtek1 is offline
post #5 of 69 (permalink) Old 11-19-2006, 01:13 PM
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Faulty O2 sensors
Mass Airflow Filter
Misfire...
Might want to try this http://www.amazon.com/s?ie=UTF8&keyw...code=qs&page=1
azinn is offline
post #6 of 69 (permalink) Old 11-19-2006, 03:09 PM
Date registered: Feb 2006
Vehicle: 2000 ml320 1986 560sel 1973 280se4.5
I had same problem. Tried cleaning but cel reappeared. Replaces MAF and removed codes 0170 and 1073. Problem resolved.
roberhelfrick is offline
post #7 of 69 (permalink) Old 11-19-2006, 06:13 PM Thread Starter
sstomcat's Avatar
Quoted: 20 Post(s)
Please tell me where I can get it for that price? Tried Autohauz price is $258...thanks
AMG 19X9.5 Wheels,
AMG Stem Valve Caps
LED Tail Lights
sstomcat is offline
post #8 of 69 (permalink) Old 11-19-2006, 07:01 PM
Kajtek1's Avatar
Kajtek1 is offline
post #9 of 69 (permalink) Old 11-19-2006, 08:09 PM
Date registered: May 2004
Vehicle: 2000 ML320
Second that. Get the MAF insert from germanstar for $129 (1120940048X). You will need a security torx bit that can be purchased from Sears and probably the chain auto parts stores.
Magweed is offline
post #10 of 69 (permalink) Old 11-20-2006, 05:33 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Try cleaning the sensor first with CRC Mass Airflow sensor cleaner. It will only cost you $6 and might solve your problem.
Mike
Michael Pillay is offline
    '99 C280 P0170, P0173, P0300 Check Engine Light rcend W202 C-Class 3 11-03-2006 03:13 PM
    Check Engine Light Elec. and P0170 Code SilverBenz W210 E-Class 0 01-11-2006 03:44 PM
    Check Engine Light On with P0170 & P0173 Code cgherndon W210 E-Class 2 12-07-2005 07:29 PM
    check engine light code P0173 tran691 W163 M-Class 6 09-05-2005 06:17 PM
    Check engine light P0170 and P0173 W163 M-Class 8 08-27-2005 07:51 PM
