Step by Step instruction on replacing window regulator on ML - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 11-03-2006, 07:02 PM   #1 (permalink)
Date registered: Nov 2006
Help!!! I need to replace window regulator, driver side, on my 2003 ML 320. Does anyone have instructions on how to go about this.
Thanks all
soulbroda is offline   Reply With Quote
Old 11-04-2006, 03:46 AM   #2 (permalink)
Bogie's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
I'm just curious, but how do you know that its not your window switch? The switch is a common failure on MLs and easy to replace. I don't advocate replacing anything just to see if it fixes a problem, but I wonder what your symptoms are. When my window switch failed, my passenger side window would go down, but would only go up in 1/2 inch increments. The window switch tray (all windows, mirrors and door lock buttons are on a single plastic tray once you remove the wood grain cover) comes out as a unit.
Bogie is offline   Reply With Quote
Old 11-04-2006, 04:16 AM   #3 (permalink)
Vehicle: 02 ML320
I agree with Bogie. Try and explain what your problem is and maybe we can save you alot of time.
43sqd is offline   Reply With Quote
Old 11-04-2006, 05:31 AM   #4 (permalink)
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Yes, just replaced mine, common problem. Those rocker switches eventually fail and you have to replace the whole panel.
ThrillKill is offline   Reply With Quote
Old 11-04-2006, 06:12 AM   #5 (permalink)
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2011 Altimta 2.5S, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Thanks all
http://www.grill.org/rodney/mclass/mlswitch/
azinn is offline   Reply With Quote
Old 11-04-2006, 06:26 AM   #6 (permalink)
4BRATZ's Avatar
Date registered: Apr 2006
Vehicle: '99 ML320
Hi Azinn,
Assuming you have determined it is the regulator that you need fix (mine snapped when putting down the window so it was heard) you will need a rivet gun, a good drill and drill bits, a second pair of hands if possible and patience. Firstly you need to take fitting from around the interior door handle off so you can undo screws and take the interior panel off (try not to break too many of the panel plugs) and remove lining. Take pictures of existing regulator (in up and down position) to use as reference and then begin drilling out all the rivets holding the regulator (about 6-8). Try not to have to resort to chiseling the tops off as the holes for the rivets in the door panel expand without too much force (and the heads on the rivets are not much bigger than the holes as is). It should take you about an hour if you have someone to help hold the window while fitting the new regulator. If you need pictures let me know as I might still have some of when I replaced mine.
4BRATZ is offline   Reply With Quote
Old 11-06-2006, 08:44 AM   #7 (permalink)
Vehicle: ML320 2001
Thanks to Rodney and his detailed instructions. It took me longer to figure out how to register and post on this site than it did to fix the switch (replaced previously by dealer under warranty twice with a switch "that does not have the same problem").
ML320 2001
Antonis is offline   Reply With Quote
Old 02-05-2007, 02:38 PM   #8 (permalink)
Date registered: Jan 2007
When my window is up and I hit the switch I hear the motor engage but the window will not move. I replaced the window switch about 1 year ago. Could it be the switch or would this be a sign of a bad regulator?
Thanks
vegashomes is offline   Reply With Quote
Old 02-09-2007, 05:13 PM   #9 (permalink)
Date registered: Jul 2005
Vehicle: 2000 ML430 105K Miles
Cost of Replacing Window Switches
What is the cost to have the dealer or qualified mechanic replace or adjust the switch contacts? Has anyone paid to have this done or is this that simple of a DIY? I'm on vacation in Florida and my drivers side window is stuck halfway. the window was going up in 1/2 inch increments for 2 days and just will not go up any longer.
dmico2 is offline   Reply With Quote
Old 10-10-2010, 08:50 AM   #10 (permalink)
Date registered: Feb 2008
Vehicle: 2000 ML320
I am having the same issue with my ML, when I hit the switch for the drivers window, I can hear the motor engage but the window will not move up or down. Is this the regulator and if so how do you change it? (Photos would be nice)
kdevaul is offline   Reply With Quote
Bookmarks
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Step by Step Installation Pioneer D2 in 2001 ML320 Builder2961 Audio & Telematics Forum 2 04-19-2008 12:00 AM
Step-by-step replacement of tail lamp lens for 126? Lazzarusman W126 S,SE,SEC,SEL,SD,SDL Class 4 06-20-2006 07:43 PM
Step by step procedure to turn on chirping for locking and unlocking (does not disable panic button) Gene R170 SLK Class 3 03-24-2003 05:32 AM
Can Linh or someone provide me with simple step by step instruction to change my shock on CLK? TIA Jeff W208 CLK Class 1 04-23-2002 10:34 AM
Brian, step by step instructions for repairing paint chips? SteveL R170 SLK Class 2 10-27-2001 07:41 AM
