» Site Navigation
» Other Sites
Old 09-23-2007, 10:43 AM   #11 (permalink)
Date registered: Apr 2006
Vehicle: 2005 ML500SE
Originally Posted by JG View Post
I had a similar issue with my 00 ML430 at around 55k. I used a code reader (OBDII Diagnostic ScanTools and codereaders) with a laptop to read my misfires over the period of 4-6 months because it was indeed intermittent. I would say about 50% of the time I would get an O2 sensor code. Before I changed that, I did the scheduled changes such as spark plugs and fuel filter. After getting the more misfires again, I went ahead and changed the 02 sensor the code reader referred to. All is fine now.
Being 68 years old I have to marvel at the automotive technology of today. My first cars were flathead Ford's. If they had a misfire we would pull one plug wire at a time to find the bad cylinder. Today we have JG spending months with a laptop to pinpoint a misfire problem, while at the same time we have i dawg 85 using a hammer to pinpoint his problem, along with as lot of common sense. Old school guys like me know when you put on a high load at open throttle and get a misfire there has to be something plugged up, especially when it clears up at low load and throttle.
Having said that, I realize the OBD's are usefull for finding bad MAF's and O2 sensors, something we didn't have on the flathead Fords. So, in spite of the new technology there are some old school techniques that are still useful!
Panzer Man is offline   Reply With Quote
Old 09-23-2007, 10:11 PM   #12 (permalink)
mclass13's Avatar
Date registered: Jun 2007
Vehicle: 2000 ML55
Maybe its the coil try swaping it with another coil and see if that cylinder still misfires
mclass13 is offline   Reply With Quote
Check Engine Light on- Cylinder 1 Misfire TyBenzo W210 E-Class 2 10-01-2006 05:30 PM
C180 - Engine Misfire / Backfire Wully_UK W202 C-Class 2 02-12-2006 07:44 AM
w202 c200 engine cut out followed by misfire montur W202 C-Class 7 12-07-2005 07:43 AM
300SD: engine misfire aadix W126 S,SE,SEC,SEL,SD,SDL Class 6 12-04-2004 08:29 PM
engine misfire at high rpm and load brian/ont W163 M-Class 4 01-10-2004 02:52 PM
