Someone in Benzworld help a brother out every morning when starting the my 2000 ML 320 The car make a loud huming noise from the engine is it the fan belt. After drive about 20 min no more huming.
Thanks its very very loud for about 20mins when i start driving and i turn the wheel its even louder.(so it sound like the air pump.)
If it's louder when you turn the wheel, then it sounds like the power steering pump. If your fluid is low, it could froth up a bit with air when you first start it and as the air gets out, it'll quieten down. You may want to check and see if your clamp located on the small return hose at the bottom right of your radiator is tight enough. This is a known issue that has been repaired by the dealer and it will fail again. There could be a slow leak there.
__________________ Be careful about reading health books. You may die of a misprint.- Mark Twain
