Help!!..brake,EST,BAS/ESP lights won't go off - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-28-2006, 04:45 AM Thread Starter
Date registered: Sep 2005
and the car won't stop beeping. I was replacing the 3rd brake light and the two small license plate lights and afterwards, the car would not start. It only took me a few minutes to swap the lights but I figure the battery might need a jump start. On first attempt, the jump start seemingly did not work. Out of curisotiy I opened the fuse box under the hood of my 2000 ML430. I pulled the relay for the ESP/BAS lights just because i was at a loss and thought maybe i blew a fuse replacing the lights. Turns out my moron of a cousin did not connect to jumper cables to his car correctly, and when I reconnected the cables to both cars my car started up instantly. Then the real trouble started! At first when I drove the car, around certain turns the BAS/ESP, EST, and Brake lights on the intrument panel came on, the car also makes a beeping noise. Yesterday was day two and the problem got progressively worse. Now the BAS/ESP and others will not go off at all(except maybe for a second here and there, while driving) the car in incessantly beeping. All the brake pads have been changed less than 1k miles ago, the fluid is fine, and the streering sensor "trick" did not work. Also, interestingly enough the car does not seem to lose performance while driving. Can anyone shed some light on this problem for me? I'm desperate for DIY answers because I can;t afford to go to the dealer right now. They will inevitably say they will fix it by replacing the motor and charging me 30k to do it, with a smile. They alwasy lie and make small problems into expenisive repairs. Any help would be tremendously appreciated. I can't deal with the beeping incessantly.
williams1279 is offline
post #2 of 10 (permalink) Old 08-28-2006, 08:22 AM Thread Starter
ok, fixed the problem...here are the details
Basically what I did was re-calibrate the brake sensor behind the brake pedal and then discontected the brake fluid sensor cleaned the contacts and topped off the brake fluid. After a couple hours driving around, all lights are still off and no beeping. I think I have statisfied the mercedes gods for today. I found this post very helpful and i did what this guys says....the link has a great brake line bleeding DIY indstrustions as well...post is about halfway down the threst by a poster named "pleubner"
http://www.benzworld.org/forums/w163...ing+constantly
On a side note, Never buy or bring your vehicle for service to RAY CATENA MB in Edison, NJ. I have been there several times when my ML430 has had various issues and every single time they completely misdiagnosed the problem and told me other more expenisve things were the culprit and needed replacing.....well over a grand in parts and labor estimate each time. Every time I fixed the issue(with the help of this board) for under 100 dollars. But i guess thats what you get bringing a car to a dealership owned by a known mafia associate....but hey, thats Jersey for ya.
post #3 of 10 (permalink) Old 08-28-2006, 08:34 AM
dewdaltz's Avatar
Date registered: Oct 2002
Vehicle: 02ML320 & 06RClass (sold)
My best advice is to have the dealer/ private MB shop "diagnose" the problem. In my case, I tried all the possible DIY thing. the lights will just comes off sooner or later. I have my lights coming on and off since last year although there is no strange sounds or driving change but it is irritating to see those lights. My ML is now at the dealer diagnosed with ABS pump failure. First, they put the computer to check all the codes and then erase all the codes then drive the ML around the block still the computer attach to the ML. They conclude that it was the ABS pump failure. check this thread for additional info.
http://forums.mbworld.org/forums/sho...d.php?t=159490
Quote 4 da` day : MODDING is very essential to make your ML very SPECIAL
dewdaltz is offline
post #4 of 10 (permalink) Old 08-29-2006, 12:52 AM
Date registered: Feb 2003
Vehicle: ML55
Williams1279 ... I sent you a PM ... I had exactly the same problem, I disconected the battery for almost 2 months when I left for vacation, after I returned and re-connnected the battery I found out that my rear - all three brake light - bulbs were burnt ... rest in PM ... good luck !!
neno is offline
post #5 of 10 (permalink) Old 08-30-2006, 01:21 PM
vballbach's Avatar
Date registered: Nov 2003
Vehicle: 98-slk230; 02-ML500; 04-slk32; 08-E55; Ford150
Had the same problem!!! Took it into the stealer and it took them 1 1/2 week to find out there was a "short" in the computer box. Cost $1200 to replace!!! Luckly i told them my car was still under warranty.
vballbach is offline
post #6 of 10 (permalink) Old 06-11-2011, 01:59 PM
veloette-ML's Avatar
Date registered: Jun 2011
Vehicle: 1999 Benz. ML430, 2006 Toyota Avalon, 2002 Jag. S-Type (sold), 1985 Benz 380-S
Question ok, fixed the problem...here are the details
What Did you mean by "re-calibrate the brake sensor behind the brake pedal "? How did you re-calibrate that switch???
My lights came on all of a sudden...I checked my brake fluid sensor and brake lights they are all OK. The dash light still won't go off? I never heard a beeping noise?
Thanks for your input,
"V"
veloette-ML is offline
post #7 of 10 (permalink) Old 06-11-2011, 03:57 PM
trickm911's Avatar
Date registered: Aug 2005
Vehicle: 99 ML430 / 92 190E Sportline
Send a message via AIM to trickm911 Send a message via Yahoo to trickm911 Send a message via Skype™ to trickm911
mine has thesame ligth came on...took it out in a shop that have the scanner.
code came out with
C1200 - Stop lamp switch(s9/1) short/open circuit
C1210- Brake Fluid level switch (s11) short/open circuit
C1025 - Can Signal Stop Lamp switch
C1140ESP - Steering angle sensor
C1141ESP - ESP break pressure sensor 1 & 2
Monday im going to find out how much to replace all sensor from a local Mercedes shop and go from there.
it also gave a code of N47-5 which is the traction control module, which cost an arm and leg. im going to do the sensor first.
trickm911 is offline
post #8 of 10 (permalink) Old 06-11-2011, 05:07 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 879 Post(s)
code came out with
Do yourself and the pocket you keep your money in a big favor, buy a Brake Light Switch from the dealer ($20) and install it.
If you have a scanner or code reader clear the codes or remove the negative battery cable for 1 min. and then re-attach.
After that turn the steering wheel all the way to the right side and then all the way to the left. This will reset the steering angle sensor on the steering column.
Then take it for a short drive making numerous turns and stepping on the brake and see if any ESP/BAS lights reappear.
Do not replace any sensors as you intend to do.
Also N47/5 is the Traction Control Module and does not need replacing. It is only mentioned in one of your codes.
43sqd is offline
post #9 of 10 (permalink) Old 06-11-2011, 05:41 PM
trickm911's Avatar
thank you for the info 43sqd..i will try and get the part on Mondau and do it myself....i will let u know....
*If you have a scanner or code reader clear the codes or remove the negative battery cable for 1 min. and then re-attach*
so you are saying if i dont have a scanner or reader..i can just remove the negative battery cable for 1 min..and it will do the work like having a scanner?
post #10 of 10 (permalink) Old 06-12-2011, 12:12 AM
Date registered: Jul 2005
Quoted: 971 Post(s)
It will clear soft codes. Hard codes will be stored in non volatile memory.
So with no power the soft codes clear out.
Noodles is offline
    Brake switch already changed - BAS/ESP ETS and other lights on mbell321 W163 M-Class 29 10-02-2015 08:36 AM
    ABS/BAS-ESP lights on - Brake lights don't work niwred W210 E-Class 12 11-27-2013 04:53 AM
    BAS/ESP and ETS lights came on Alex///AMG W163 M-Class 46 07-04-2011 10:07 AM
    ABS/BAS-ESP lights on and no brake lights niwred W210 E-Class 3 11-28-2004 05:48 AM
    ESP BAS ABS lights land747 R129 SL-Class 1 10-20-2004 09:51 AM
