To change or Not to change? -- That is the ML320 transmission fluid question!! - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-19-2006, 05:24 PM Thread Starter
Date registered: Jun 2006
Vehicle: 2000 ml 320
My daughter has a 2000 ML320. She bought it used and it has about 65,000 miles. Although it is functioning properly now, I was wondering, after reading several posts pro and con, if I should advise her to have the fluid and filter changed or not. I would like your input. If you favor a change, does it need to be from the MB dealer, any trusted mechanic or could I do it?
Thanks in advance for your help!!
ebrington is offline
post #2 of 15 (permalink) Old 07-19-2006, 06:26 PM
John_L's Avatar
Date registered: Apr 2005
Vehicle: 2005 ML350 SE; Former 1999 ML320 (281K miles)
I did both the tranny and differential fluids at 78K miles. Noticed it shifted smoother afterwards. I had it done by my MB dealer since I trusted my SA. I look at this maintance issue as cheap insurance. I would do it if you are planning on keeping the ML.
John_L is online now
post #3 of 15 (permalink) Old 07-19-2006, 06:26 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 35 Post(s)
I spoke with my MB Master Tech about this a couple of years ago and he adviced me that if I intended to keep the vehicle past 100K, I should get the tranny fluid changed at 60-70K. Additionally, based on several posts about the ML's tranny, and given that you have no idea how the previous owner used this truck, I'd advice you to change the tranny fluid, along with the transaxle fluids. It's extremely cheap insurance.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
post #4 of 15 (permalink) Old 07-19-2006, 08:39 PM
candrews's Avatar
Date registered: Aug 2003
Vehicle: 2002 ML55
Send a message via AIM to candrews
What does the stealership charge to change Tranny fluid?
candrews is offline
post #5 of 15 (permalink) Old 07-19-2006, 09:36 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
How do you know "you did it"?
There is a news crew investigation cruising on the net, where out of 10 Jiffy Lube stations, that charged customers for changing transmission fluid with "special, sophisticated machine" only 3 actually did.
You think MB dealers are better?
Kajtek1 is online now
post #6 of 15 (permalink) Old 07-20-2006, 01:45 AM
John_L's Avatar
I paid $265 for the Tranny fluid, filter, and gasket. Parts $85 and labor $180.
The key is finding a trusted mechanic or shop that knows about fixing the ML, it could be an indy or a dealer.
post #7 of 15 (permalink) Old 07-20-2006, 02:59 PM
Vehicle: '05 ML350SE
I implicitly trust all dealers. That trust is backed up by my presence: I always stand there, watch the tech, and sometimes chat with him. I have only caught one dealer charging me for a service not performed.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 130k miles
mickey.1430 is offline
post #8 of 15 (permalink) Old 03-19-2011, 03:27 PM
Date registered: Dec 2010
Vehicle: 2 wheel drive W163 and W124
Quoted: 7 Post(s)
Haha I went to the stealership today and the parts manager tried to tell me to only replace 4quarts. Im going to look for the drain plug on the torque converter and drain that as well.
Anyways, im changing the fluid filter and gasket! The truck has reached 200k and is starting to feel sluggish despite having a new engine with 40k on it... Getting that thump when accelerating and decellerating.
loclark757 is offline
post #9 of 15 (permalink) Old 03-19-2011, 03:53 PM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Eventhough this is a 4 year old thread...keep us posted - maybe take pics and make a DIY if there isn't one already?
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #10 of 15 (permalink) Old 03-19-2011, 04:10 PM
Quoted: 7 Post(s)
Just remember you turn the crank clockwise to find the drain plug on the torque converter!
I'll try to make some pics.
This is what im using:
Duralast pan gasket and filter, 8 quarts Mobil 1 Synthetic, drain plug washer for the pan and the torque converter, new red pin for dipstick tube filler
I just did the the same thing to my E320 and it turned out great. More power to the wheels im going to start doing tranny fluid and filter changes every 30k.
HOW DO I CHANGE THE TRANSMISSION FLUID? DETANE1 W210 E-Class 19 10-12-2006 06:32 AM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 11 08-17-2006 04:31 PM
When Do I Change Transmission Fluid dick.oliver W140 S-Class 7 06-15-2006 05:28 PM
El Cheapo question on transmission fluid change dave lackey W163 M-Class 9 10-26-2005 09:33 AM
Transmission fluid change alex lynch W163 M-Class 1 11-29-2002 02:29 PM
