» Site Navigation
» Other Sites
Old 03-29-2006, 12:14 PM   #1 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
Transfer case and differential fluid change questions
I did a search and found the article from Star regarding changing the forward and rear differential fluid and transfer case fluid.
The article states: torque both plugs....can someone tell me the torque specs for the forward diff, rear diff, and transfer case plugs?
Also, I went out and bought the fluid. Is valvoline SAE 80W 90 okay to use for the diffs? The article says to use SAE 90. I dont know if the "80W' part will be a problem.
Thanks,
Mike
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 03-29-2006, 03:49 PM   #2 (permalink)
Vehicle: '05 ML350SE
RE: Transfer case and differential fluid change questions
The Valvoline product is a multi grade type which acts like an 80W fluid at low temps and a 90W fluid at high temps. It should work just fine in the diffs.
Presumably you purchased non synthetic ATF for the transfer case as is called for.
I don't have the torque specs but I am guessing you can figure them out by removing the plugs.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 48k miles
mickey.1430 is offline   Reply With Quote
Old 03-29-2006, 05:20 PM   #3 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
I changed all fluids myself. The transfer case required a salon bottle with a slanted tip for pouring in the top plug hole. I used Dexron III ATF for the transfer case but my mechanic recommended I switch to the synthetic since it lasts longer. He said the return of the clicking noise after 5000 miles is indication the fluid isn't up to snuff. I really don't see why synthetic can't be used but if someone knows something I don't, please tell it!
cmitch is offline   Reply With Quote
Old 03-30-2006, 10:20 AM   #4 (permalink)
I did the front and rear diff this morning. Pretty easy. The most annoying part was getting the oil into the fill plug on the rear diff. Not a whole lot of space back there. I need to find the square 3/8 inch drive for the transfer case. Sears did not have anything like that when I checked.
Mike
Old 03-30-2006, 04:51 PM   #5 (permalink)
Premium Member
cmitch's Avatar
Premium Member
Michael Pillay - 3/30/2006 1:20 PM
Mike
Use the 3/8 inch EXTENSION. It works like a charm.[;)]
Old 03-30-2006, 07:51 PM   #6 (permalink)
Date registered: Jul 2005
Vehicle: 99 ML430, 90 300E,
I thinks me be suffering from deja vu[:o)]
Noodles is offline   Reply With Quote
Old 03-30-2006, 07:55 PM   #7 (permalink)
Premium Member
cmitch's Avatar
Premium Member
Noodles - 3/30/2006 10:51 PM
Yep. I posted this and noticed his other thread. opened it and there it was, the same suggestion. It's funny how us Extremist/Elitist think alike!![8D]
Old 03-31-2006, 04:25 AM   #8 (permalink)
Date registered: Dec 2003
Vehicle: '99 ML430
Are any additives used by M.B.?
esp. for the rear diffs?
gw17625410 is offline   Reply With Quote
Old 03-31-2006, 05:35 AM   #9 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
BE VERY CAREFUL WHEN TIGHTENING THE TRANSFER CASE SCREW!!!
I over thightened mine and the whole cover cracked!! Didn't seem to apply that much torque. Fortunetely, my friendly dealer replaced the entire TC under Starmark warranty.
Sergio
'99 ML430 87K miles
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 06-01-2006, 02:08 PM   #10 (permalink)
Date registered: Jun 2006
Vehicle: 2007 Saturn Outlook (sold 1998 ML320)
Would you mind posting that Star article? I had been having a knocking noise coming from under my ML320. The AAA diagnosic center recommended that I try replacing the transfer case oil. I convinced the guys at Jiffy Lube to do it ($30) with my oil (MB type 6 AT fluid - recommended by MB for w163 (w164 uses type 9) @$15/quart (needed 2.5 quarts)). Also needed a liquid pump ($17 at Kragen). So for about $100 the noise is gone. However, the oil was nearly black with silvery flicks in it so I have the suspicion that this may not be the end of this problem. I'll change the oil again in a few weeks to make sure its clean.
Dueysf is offline   Reply With Quote
