21 - 40 of 217 Posts
Discussion starter · #21 ·
7. Door Lock!!!!
... now lets remove that lock ..... OH NO! ..... won't come out ..... the bloody window guide rail is blocking it!
.... reminds me of the clint Eastwoods film "Every which way but...."
...Oh well out come that window rail! .... by the way it's stated in the WIS also!
Discussion starter · #25 ·
RE: 8. Remove Window Rail
drill the head slighty ... careful, not too much! We don't want to make that hole bigger!!!
.... then chisel the head off (I forgot photo for that one..... what a catastrophy!!! You won't be able to do the replacement now! ... just kidding! )
[:D]
Discussion starter · #28 ·
9. Move lock knob to new lock
... now lets look at the parts goodies box!
... Notice the new part comes with the pull lever , but not the knob. You need to take it off the old one. The thread on the pull lever is not rounded (see photos at the end) , but has a flat side. This means that you only need turn the know 90 degrees (... celcius not fahrenheit , heh,heh .... just kidding!) ,,.....then pull out.
The idea here is that you can positionthe knob a the depth you require , then twist to secure it.
Discussion starter · #33 ·
RE: 12. Replace the Window guide rail
YOu can either unclip the lift connector , or unscrew the lock again! We chose to unscrew the lock as it was a lot easier to manouver the rail in place!
NOTE: As said earlier don't screw the lock in place until you have the guide rail in position.
Discussion starter · #35 ·
Now lets rivet that rail in place .... WOW that's what I call a rivet gun! .... You are going to use a lot of "elbow grease" (muscle) getting those rivets done using your everyday handyman store rivet gun!
Glad he didn't get out the compressed air version or I would'nt have been able to continue with my DIY!
[:D][:D][:D]
Discussion starter · #37 ·
NEW DOOR LOCK PINS (KNOB)
I took the opportunity to setup a more refined look with pins from "matrixcar.de".
Ignore this step if you are not interested in new pins
[:I][:I]
Discussion starter · #40 ·
RE: 14. Replace inside door handle bracket
Slide the bracket to the rear.
NOT HARD UP AGAINST THE END!!!! YOU WILL HAVE PROBLEMS ATTACHING THE REAR OUTSIDE END PIECE OTHERWISE
..... push up against the end , then move back a little.
