» Site Navigation
» Other Sites
Old 12-15-2005, 07:47 AM   #1 (permalink)
uptown's Avatar
Date registered: Oct 2005
Vehicle: 99 ML430, 02' C320
out of windshield washer fluid
stealership is 50 miles away and it just started to snow here in VA, I'm hesitant about buying the cheap blue fluid. Any suggestions???
uptown is offline   Reply With Quote
Old 12-15-2005, 07:50 AM   #2 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
RE: out of windshield washer fluid
uptown - 12/15/2005 10:47 AM
buy the blue fluid
roadsession is offline   Reply With Quote
Old 12-15-2005, 09:11 AM   #3 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
roadsession - 12/15/2005 9:50 AM
buy the blue fluid
Hell no! Get in the ML and drive yourself to the dealer and buy the proper citrus-scented Mercedes-Benz washer fluid. Otherwise, you will void your warranty, destroy your transmission, require AAM recoding, and your MAF, CPS, and O2 sensors will all fail simultaneously! [:D]
Seriously, there’s nothing wrong with the blue stuff, but nothing beats the real thing!
- RODNEY
rudeney is offline   Reply With Quote
Old 12-15-2005, 09:17 AM   #4 (permalink)
uptown's Avatar
lol! thanks guys
Old 12-15-2005, 09:20 AM   #5 (permalink)
Vehicle: '05 ML350SE
Is it OK to use gas station air in my tires?
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 48k miles
mickey.1430 is offline   Reply With Quote
Old 12-15-2005, 10:02 AM   #6 (permalink)
Swizzles's Avatar
Date registered: Jul 2004
Vehicle: 04 G55AMG, 03 C320 4matic, 98ML320
Send a message via MSN to Swizzles
uptown - 12/15/2005 8:47 AM
I always use Rain-x. It is yellow, it creates a coat of something on the widshield that beads up water and sends it sheeting off for improved visability Plus it melts frost no need to get out the scraper. Magic stuff!
Swizzles is offline   Reply With Quote
Old 12-15-2005, 10:14 AM   #7 (permalink)
Date registered: Jan 2005
Vehicle: 1999 ML430
pretty amazing.......but some tire installers (such as Costco) are touting the benefits of filling your tires with NITROGEN to prevent pressure variations.
springerfever is offline   Reply With Quote
Old 12-15-2005, 11:17 AM   #8 (permalink)
rudeney's Avatar
Vehicle: 2001 ML320
Using nitrogen to inflate tires is actually not all snake oil. There is some science to it. Using compressed atmospheric air does put moisture in the tires and it has a much greater variance in pressure over a range of temperatures. Now, as to whether or not that actually has any bearing on handling or fuel economy remains to be seen. Regardless, the places using nitrogen aren’t charging any more for it (although Costco likes to put tacky green caps on the valve stems).
Old 12-15-2005, 11:30 AM   #9 (permalink)
Darkmann's Avatar
Vehicle: Anything w/Wheels
mickey.1430 - 12/15/2005 12:20 PM
No!!! You'll spontaneously combust. There's something in the MB air that makes gas station tire unsuitable!!!
1989 300ZXT - mine
A pair of running shoes
A 18Hp lawn mower
2 Mountain Bikes
350Z - will be mine when @ 300+HP and 3-Car Garage
Darkmann is offline   Reply With Quote
Old 12-15-2005, 11:59 AM   #10 (permalink)
Date registered: Aug 2005
Vehicle: 01 ML 320
As a warning, I've had the washer fluid w/de-icer disolve my blade inserts so you might want to go with the plain-jane blue fluid.
_Dennis_ is offline   Reply With Quote
