Old 11-06-2005, 09:04 AM   #1 (permalink)
Date registered: Feb 2005
Vehicle: 2000 ML430
Brake rotor brands
I see ML rotors from Brembo, Zimmerman, ATE and perhaps Balo. Brembos are the cheapest.
Q1: Which brand is Mercedes using for 2000 ML430 fronts?
Q2: Are the Brembos as good as the others? Someone on this forum said that Brembos are easier to warp.
Q3: Which brand should I use (USA market) if I want better quality, or, should I just pay extra for the official Mercedes rotor?
I have no interest in drilled/slotted rotors as I know that they don't do anything for legal street driving (other than look good).
DelJ
DelJ is offline   Reply With Quote
Old 11-06-2005, 10:52 AM   #2 (permalink)
candrews's Avatar
Date registered: Aug 2003
Vehicle: 2002 ML55
Send a message via AIM to candrews
RE: Brake rotor brands
I don't (or would be surprised) that anyone said the Brembo's we're bad but I do think that someone probably said that the drilled and cross slotted are easier to warp or crack and also could result in quicker pada wear.
I use Brembo's on front and rears with no issues.
candrews is offline   Reply With Quote
Old 11-06-2005, 11:08 AM   #3 (permalink)
Wolfgang's Avatar
Vehicle: MBs
DelJ - 11/6/2005 8:04 AM
Brembo.
Wolfgang is offline   Reply With Quote
Old 11-06-2005, 12:01 PM   #4 (permalink)
C-Rod's Avatar
Date registered: Oct 2002
Vehicle: 2006 ML 350.
l've always use Brembo's with no problems...Though, l've only used cross-drilled..never slotted...
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux AMG ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 53,000 KM (stolen)
2006 : Cubanite Silver ML 350 : 24,000 KM
C-Rod is offline   Reply With Quote
Old 11-06-2005, 12:11 PM   #5 (permalink)
MADSLEG's Avatar
Date registered: Jun 2005
Send a message via ICQ to MADSLEG
l use drilled and slotted Brembo's and i have no problems with them
pics of rear and front
Green Emerald ML(debadged),M1 package,Ventvisor window deflectors,02+ halogens,Crystal Side Lamp with Chrome Rim,front Bilsteins,Body Colored Bumpers and moldings,silver painted ML55 Chrome Grill Stripes,Chrome Door Handle Covers,SCHATZ Burlwood & Chrome Shift knob-SCHATZ Burlwood shifter surround
,5% tint all around,Jensen VM9022 indash DVD player with NAV101 navigation module,2x12" DUB subs powered with 1000 RMS watt diGital MAaudio mono amp,20x8.5" triple chrome ADRs,Brembo D/S rotors.
MADSLEG is offline   Reply With Quote
Old 11-06-2005, 12:47 PM   #6 (permalink)
Vehicle: 2000 ML430
Donho mentioned on this W163 forum that he warped Brembos on a Maxima sedan, however, the concensus here is that Brembos are the way to go.
DelJ
candrews - 11/6/2005 9:52 AM
Old 11-06-2005, 06:39 PM   #7 (permalink)
Date registered: Jul 2005
Vehicle: 99 ML430, 90 300E,
You won't go wrong with Zimmermans also. All the German car makers have used them in the past and currently on some models. On our 90 300e I was able to find out they were not Brembos, but in fact Zimmermans from the factory.
Brembo does make a quality product and would not hesitate to buy them.
Their reputation for warping on the Japanese cars is not Brembos fault. A lot of the cars like Accords, Camrys, Maximas etc.... have thinner specs for their rotors. If the driver is a heavy braker then almost any brand can be warped. I got rid of my Prelude Vtec for that reason. I was going thru brakes every 15,000 miles and each time the rotors were junk. Granted I autocrossed the car a lot, but the brakes on my lowly GTi were far more durable. Adding cooling ducts would have solved the Vtecs problem, but would have bumped me out of the stock class. Even autocrossing the GTi I got more than double the wear of the Vtec. Used Zimmermans on the front and Brembos on the rear. The Zimmermans were cheaper up front and the Brembos were cheaper for th rear. Pads were Mintex.
Noodles is offline   Reply With Quote
Old 11-07-2005, 12:40 PM   #8 (permalink)
Date registered: Sep 2003
Vehicle: '02ML320
Zimmerman's on my ml. replaced all four corners about 25k miles ago. Still have much life left in them.
onesixthree is offline   Reply With Quote
Old 11-07-2005, 05:34 PM   #9 (permalink)
washington dc ML's Avatar
Vehicle: 1999 ML430
I've warped brembo blanks on my Maxima and cracked cross drilled. Slotted worked the best on the Maxima. I currently use Zimmerman Cross Drilled on my ML.
DelJ - 11/6/2005 2:47 PM
DelJ
washington dc ML is offline   Reply With Quote
Old 12-30-2005, 11:45 PM   #10 (permalink)
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
I think Zimmermans has wear indicators on their rotors too. So you don't need to guess how much rotors you have left. However I do change my rotors every two sets of brake pads because I don't want to have my rotor get stuck on my hub with rust. (sledgehammer time)
Current setup
Front: Porterfield R4-S + Zimmerman x-drilled
Rear: Mintex OEM + Brembo solid.
Note: Porterfield has heat cycle issues. So the pad material will die before it's worn out.
ae86pwr is offline   Reply With Quote
