My local shop gave me that quote. I haven't got a quote from the dealer but I assume it is higher. What is your experience for pricing for rear brakes and rotors?
RE: Is $650 for rear brakes and rotors reasonable?
I was quoted around $500 for both front and rear pads and rotors for OEM stuff. I also asked the dealer for the price brake pads and rotors and they said somewhere around $650 + tax, not incl labor. Hope that helps.
My MB dealer quoted $1000+ for pads and rotors all around [:(]
I went to local shop requested for OEM Pagid Pads, Zimmerman/ATE rotors and flush the brake fluid; I paid $650 for everything [:)]
Next time I will DIY [^]
Good luck
To change the brakes on all four wheels on my ML takes less than one hour per axle, and that’s using a floor jack. Of course I have a lot of “shade tree� experience, but I can’t imagine a trained mechanic with all the right tools, experience and a vehicle lift taking any longer. My guess is even at inflated prices, $100 per axel should cover the labor. The most high-priced performance pads and rotors are around $500 per axle, but OEM pads and rotors are less than $300 per axle. This means that a brake job on the ML should run between $400 (OEM parts) and $600 (performance parts) per axle. Anything more than that and you’re getting soaked.
