Old 04-11-2008, 06:19 AM   #31 (permalink)
Date registered: Apr 2004
Vehicle: ml 320 1998
Unhappy fuel
i only seem to be getting 5 volts to the fuel pump?
gravel is offline   Reply With Quote
Old 04-11-2008, 12:09 PM   #32 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Measured where? The crimp electrical connections on late MB are not the strong points. You need to track the voltage drop from the fuse panel.
Kajtek1 is online now   Reply With Quote
Old 05-27-2008, 01:53 AM   #33 (permalink)
Date registered: May 2008
Dose anyone have a diagram on how to change and remove fuel filter??
pmille1 is offline   Reply With Quote
Old 05-27-2008, 03:33 AM   #34 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Please take a minute to update your profile in USER CP to the left, to include the year and model of your truck.
Not knowing the year of your truck, or whether or not you have the upgraded filter, you will have to remove the L/R wheel and the liner and compare the filter and number of lines as depicted in drawing on page 2 of first PDF.
If your filter looks identical to the drawing then just follow the instructions in the second PDF.
If your filter does not look identical to the drawing then you must follow the instructions in the first PDF, which requires the addition of another line. Purchase the filter and line (if necessary) at the dealer.
43sqd is offline   Reply With Quote
Old 05-27-2008, 04:23 AM   #35 (permalink)
Wink pump
change the pump, i got mine replaced and its now a different car.
Old 05-27-2008, 05:56 AM   #36 (permalink)
Vehicle: 02 ML320
Gravel, he didn't say he had a problem. He justs wants to know how to change the filter.
Old 05-27-2008, 10:45 PM   #37 (permalink)
Vehicle: ML 320 W 163 1998 AND S500 W 220 2001
Send a message via MSN to EUROPEANSPORT
HEY 43SGD,
CAN YOU HELP ME ? I HAVE 98 ML 320 I HAVE LACK OF POWER IN TOP LOW RPM IS GOOD. GOT A LOT OF ERROR CODE S LIKE BANK1 LIMIT HAS REACHED ITS LIMIT, MISFIRE CYL 1 AND THREE. MY CATS WERE BAD I HAD THEM EMPTIED OUT. IT HAS BETTER TOP POWE RNOW BUT STILL NOT ENOUGH. DO YOU THINK IT CAN BE CRANK SENSOR GOING BAD IN HIGH RPM ? OR DO YOU THINK FUEL ISSUE. LOW RPM IS PERFECT SMOOTH RUNNING ENGINE.
EUROPEANSPORT is offline   Reply With Quote
