Old 10-03-2005, 08:30 PM   #1 (permalink)
Date registered: Sep 2005
Help... My entire instrument cluster just died...
Any idea what it could be? I looked at fuse box but don't see a fuse for it... HELP!!! Nothing comes on in the cluster
orlandotrader is offline   Reply With Quote
Old 10-03-2005, 10:22 PM   #2 (permalink)
redeye's Avatar
Date registered: May 2004
RE: Help... My entire instrument cluster just died...
On your 2000 model, the following fuses and relays have some bearing on the instrument cluster. Check them all as a starting point:
Passenger footwell: F1, F5.
Main box under the hood: F16, F2, F25, F5, F9, K5 (relay), K12 (relay).
redeye is offline   Reply With Quote
Old 10-04-2005, 12:33 AM   #3 (permalink)
Andrew2004az's Avatar
Date registered: Feb 2004
Vehicle: 02 ML 320
i know this sounds crazy but give it a day it will come back. mine has gone out many a time and comes back on in a day. its worth a try and doesnt cost anything. unless its been out for a few days then its a fuse it doesnt sound like a bulb it would be very rare for all the bulbs to die together.
Andrew2004az is offline   Reply With Quote
Old 10-04-2005, 07:27 AM   #4 (permalink)
Would this explain why nothing works? Still does not work this am... I was able to drive the car to work.
Old 10-04-2005, 08:04 AM   #5 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
Try removing it and re-installing it (there are instructions here somewhere – it’s an easy job). Take special care to insure that the electrical connector is properly seated and locked in place. It’s possible it has come loose, probably because the dealer replaced bulbs in it and did not securely connect it.
EDIT: Look on Ken's site for instructions:
http://www.keysolutions.com/M-Class....t%26AutoFramed
- RODNEY
rudeney is offline   Reply With Quote
Old 10-04-2005, 09:52 AM   #6 (permalink)
Vehicle: 98ML320
Are you saying nothing works at all (ie:speedometer, gas guage and trip computer is out) or is it just all the lights are not lighting up but everything works?
bigcatny is offline   Reply With Quote
Old 10-04-2005, 11:22 AM   #7 (permalink)
Nothing at all. Its like it doesnt have any power., No lights, no speedo, nothing...
Old 10-05-2005, 09:40 AM   #8 (permalink)
Works this morning. All I did was disconnect battery and reconnect. THANKS FOR ALL YOUR HELP
Old 09-27-2008, 09:22 AM   #9 (permalink)
dfskinner's Avatar
Date registered: May 2003
Vehicle: 1999 ML430
I've noticed mine just started not responding until after the car has been on for approx 3 to 5 seconds....... wasn't like this until just yesterday.....
1. Start car..... gas guage, temp gauge normally respond right away, but now they're both taking the 3 to 5 seconds to respond.......
Can you guys check and see if your are responding right away........
And something else I noticed, after I turn the car off their turning off (moving to the off position) but the gas guage seems to be ticking for about 3 to 5 seconds after I turn the truck off, never seen this before? Wanted to check with the board before I start checking for a fuse that's blown or a relay that's out.....
Dennis
If you don't know where you want to go....
"Then it doesn't much matter how you get there"
1999 ML430
1998 Toyota Tacoma
1996 BMW 318is
2006 Mazada 5
2006 Infinity FX35
dfskinner is offline   Reply With Quote
Old 09-28-2008, 12:18 PM   #10 (permalink)
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430
EXACT same symptoms happened to me right before my extended warranty ran out. Got a new cluster out of it. Maybe there is a simpler solution, however I didn't mind getting a new cluster.
2000 ML430
Chrome grille, tailgate latch, logo on rims, instrument cluster rings - K&N air filter - Ate brakes - projector style lights w/xenon bulbs - white LED lights on licence plate - handpainted pinstripe - designo Java Shift Surround - brushed aluminum roof rails
Newly Updated! Click to read the New Members Guide
bocabenz is offline   Reply With Quote
