what does the BAS ESP light mean? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-27-2005, 03:45 AM Thread Starter
Date registered: Jul 2005
i was driving my car today and suddenly the accleration shut down, it seemed like the call stalled and the BAS ESP light turned on. i stopped the car and restarted it, it worked fine.
what does that BAS ESP light mean
and
why does it turn on? is there a way to prevent it from turning on.
and also, when i start my car and begin to drive, the engine seems to lag. i step on the gas but it doesn't really accelerate. the rpm doesn't go over 2.5x. this happens for a little bit then it beings to run smoother.
any idea why this happens?
thank you
essence is offline
post #2 of 6 (permalink) Old 08-27-2005, 10:54 AM
Benz4Dirt&Sky's Avatar
Date registered: Sep 2002
Vehicle: ML430/ SL500 SA
RE: what does the BAS ESP light mean?
I am not an expert, but here are my thoughts...
You have a bad sensor.
That indicator means there is a problem detected with your traction control (electronic skid protection) system.
I am speculating, but if the system detects what it thinks is a difference in wheel speed it will cut throttle and/or apply brake to balance it out.
It sounds like the system thinks you are spinning a wheel in a loss of traction scenario, or that you are entering a turn to quickly.
Get it checked out.
My light has gone on before after driving through deep water pulling my boat out of the water...but there was no associated change in behaviour of the ML and it went off the next time I started the car.
Wolfgang has some great info on his site:
http://www.whnet.com/4x4/esp.html
"I feel much better ever since I gave up hope."
1999 ML430 * Navigation System * 285/70 R17 All terrain T/As -33 inchers*ORC suspension lift kit* Side Step Rail Rock Sliders * Brush Guard * HELLA lamps * Front Skid Plate* All Weather Mats * All-Terrain Rear Seat Cover * Wet Okole Neoprene Front seat covers* All-Weather Rear Cargo Mat/Divider * Yakima LoadWarrior Rack * Roofmount Fullsize spare * Trailer Hitch * Rhino Hitch Step* Rhino Tail Light Guards* WARN 8000i Multi-Mount Winch* Go-Light Remote Motorized Spotlight * Moto-Jack Motorcycle Carrier
2002 SL500 Sliver Arrow w/limited edition James Bond briefcase
Benz4Dirt&Sky is offline
post #3 of 6 (permalink) Old 08-29-2005, 06:24 AM
Date registered: May 2005
Vehicle: 2001 ML 320
My buddy's ML500 did this when he stomped on it at a stop light...he drive it home with no troubles and cleared the code with his ODBII scanner.
treeman5 is offline
post #4 of 6 (permalink) Old 08-29-2005, 10:11 AM
Mercedes Boy's Avatar
essence - 8/26/2005 2:45 AM
and
thank you
Firdt of all.........what year, model is your ML????
Mercedes Boy is offline
post #5 of 6 (permalink) Old 08-29-2005, 06:15 PM Thread Starter
i have a 2001 ML 430
essence is offline
post #6 of 6 (permalink) Old 08-29-2005, 07:02 PM
Vehicle: Black 2005 ML 500
My guess is that you have a bad sensor, too. When my vehicle was new, everytime I accelerated fast, my ML will sudden choke down and the BAS/ESP light will come on and you would hear the brakes vibrating trying to incorrectly adjust the speed/direction.
This was different from the fuel pump problem in that a bad sensor will normally just slow down, the BAS/ESP light will come on, and you will hear the brakes vibrating normally on the wheel with the bad sensor.
Good luck..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Yokohama Geolander HTS + Bi-Xenons(+ Drew's e-code mod, though the reflectors rusted off and do not give out much light anymore), Yakima roof bars, Akebono pads all around. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After all these years of owning my current 2005 ML 500, it is a major unreliable vehicle with a very large/expensive repair/defect history and has been like this since brand new.
AC_ML is offline
