Old 08-17-2005, 02:00 PM   #1 (permalink)
Date registered: Jul 2005
-36' F ??
I've got a '99 ML 320 that always shows this on the temp display. Has anyone experienced this particular problem? I searched but it seems like the most common problem is the light going out.
newsteve is offline   Reply With Quote
Old 08-17-2005, 02:29 PM   #2 (permalink)
Date registered: Sep 2004
Vehicle: 2004 ML350
RE: -36' F ??
Maybe the temp sensor is disconnected or broken.
2004 ML350 Black with charcoal leather, OEM Hitch, Rhino step, Bose, Navigation, OEM front guard, Comfort package, Entertainment package, Sunroof, heated seats.
2bmj is offline   Reply With Quote
Old 08-17-2005, 02:35 PM   #3 (permalink)
redeye's Avatar
Date registered: May 2004
RE: -36' F ??
Definitely means the temp sensor is not functioning. Open your hood, towards the driver's side of your bumper grill (in front of the 2 aux.fans) you should see the temp sensor mounted into the bumper (it clips in). Follow the lead, find the connector and plug it in if disconnected.
redeye is offline   Reply With Quote
Old 08-17-2005, 03:08 PM   #4 (permalink)
RE: -36' F ??
Thanks, if the sensor is supposed to have a plug with two wires go into it; I guess mine is missing. I see the plug hanging and what looks like a spot for the sensor to clip on, but no sensor. My girlfriend bought the truck used a few yrs ago.... maybe some forgetful bodyshop worked on it.
Old 08-17-2005, 03:22 PM   #5 (permalink)
redeye's Avatar
RE: -36' F ??
There are normally a couple of plugs and leads hanging there (for external foglights and block heater if you have). Find the spot where the temp sensor mounts into the bumper and work from there. To get to it you can also unclip the small bumper grill in the middle of the bumper (it pulls of easily) to see the mount - it is a little round hole in a plastic tab attached to the bumper, towards the driver side of the car but still in the bumper grill opening. If the temp sensor is there, it looks like a small black "pencil" protruding through the hole. If it's not there and not hanging somewhere behind the bumper, it is probably gone.
Old 08-17-2005, 07:15 PM   #6 (permalink)
Darkmann's Avatar
Vehicle: Anything w/Wheels
Didn't you just get transferred to iceland??
newsteve - 8/17/2005 4:00 PM
Anyway, temp sensor may be bad.
1989 300ZXT - mine
A pair of running shoes
A 18Hp lawn mower
2 Mountain Bikes
350Z - will be mine when @ 300+HP and 3-Car Garage
Darkmann is offline   Reply With Quote
