My transmission on my 99 ML430 seems to slip into gear under hard acceleration. Normal day to day driving and rush hour traffic I have no problems, but when I try to "gun it" it seems to just sit, then slide into gear. The engine makes noise like it's moving and the RPM rise but other than that it seems like I'm not picking up speed as fast as I should.
Has anyone had this problem?
but not for a while now. The engine revs up and there is this hesitation as if the ML is trying to decide which gear to go in to and once it makes it's decision all those RPMs are kickin' and so it will take off and you can feel the rush--except for me there wasn't any hard jerking of the trans once it engages in the gear of choice. I found this happened when I was on an incline and/or the road was really rough so the MLs "shoes" did not have stable footing. It's hard to actually make it happen (I tried to repeat it so I could share with the dealer but was not able to make it happen when I wanted to). If it happens very frequently then there might be an issue but I can not advise what that issue is--since I don't know. Anyone else?
MODS:Kleemann Kompressor\Hardwired Valentine One\Burl/Black leather Armrestcover\Rear Burlwood Switch Cover\Burlwood/Ash Leather Shift Knob\Chrome Gear Shift Encase Set\Single Flat Burlwood Drinkholder\Burlwood/Black Leather Steering Wheel\Bose Tweeters w/ Sail Panels\Wood Trim for 3 Vents\Wood Dash Kit\Glove Box Organizer\Chrome A/C Switch Rings\Burl Frame for Instrument Panel\"nr" White Instrument Gauge Face\Chrome Gauge Cluster Rings\Passenger Floor Cargo Net\MB Stainless F&R Door Sills\MB Rubber Floor Mats\Cargo Tray with Organizers\Hella Bi-Xenons\LED front turn signals\Chrome Sport Grille\PP Chrome Front Bumper Grille\chrome head light rings\Hella xenon micro DE Foglights\Tailgate Filler Panel\Rear Spoiler w/ clear/red LED brake light\45 LED 3rd Brake light\'02 Tailights w/ LED brake lights and wired-blinking side markers\chrome taillight rings\Supersprint Muffler & Exhaust Kit w/signature Round Supersprint Tips\Chrome Tailgate Handle\AMG 18" Rims w/ DUNLOP SP 9000s\MB Blue Laurel Center Wheel Cap Emblems\Red calipers\Cell Phone Antenna\Lamella Skyview Wind Deflector\OEM Fender Flares\MB Polished Stainless Steel Step Bars\AMP Alloy Fuel Door Flap\Chrome Side Indicator Frames\Kleemann "K" and G-klasse "8" Side Emblems\Chrome Door Side Strips\Chrome Shell Inserts\chrome door handle covers\Chrome window sill covers\LED blinking side view mirror covers\12.1" Directed Video LCD OHD w/DVD.
THANKS: Cory @ Kleemann USA\Axel, Jim, & Cliff @ Knauz MB of Lake Bluff\MB of Westmont\Andrew Ling\Jerry @ ForMyMercedesdotcom\Performance Products\Park Place MB Texas\tirerack.com\MB of Naperville\JP Mercedes of Lasalle-Peru\Ben @ evosport\AMP Research\drinkholders.com\exoticwooddash.com\Rodne y\& many thanks to Pleubner...the king publisher of the ML mods from Benzworld.org
MY00 ML320
65K miles / Black Opal / M1 Package
Sunroof / Heated Seats / CD Changer
Mods: Front Plate delete / Badge delete /35% tint front windows / OEM Trailer Hitch / OEM Step Bars
MY97 Porsche Boxster
53K miles / Ocean Blue / Sport Package / Hard Top
Mods: B & M Short Shifter / MY00 Shift knob & boot / SS intake grills / Badge delete / front plate delete
Track/AutoX Shoes: Kumho Victoracers
Street Shoes: Kumho Ecsta 712's
J-bird, what did you enter when you did your search? My right brain(I'm a lefty) thought pattern just can't find the correct phrase for search engines sometimes.
When you say "gun it", are you meaning pushing the accelerator until you feel the click of the push botton at the end of the accelerator...?
If so something may be wrong.. You may want to get a service transmission oil stick and measure your transmission oil. Remember that you need to get a new cap since the transmission cap is not reusable.
ML 320 engines transmission design are notorious for slipping when you accelerate (cars or SUV's). They just rev up until 3000 or 4000+ RPM and then the gear kicks in. Unless you push the accelerator until it clicks the button at the end of the accelerator, which when pushed, it should immediately shift down gears for quick response.
I haven't hear any people complain about this on any engine above the 350, though..
Good luck...
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After 3 years of owning my current 2005 ML 500, it has become another unreiliable vehicle with a very large/expensive repair/defect history..
I have the same thing happen to me. but it only happens when you gun it and your car needs to downshift 2 gears. our 5spd autos cant skip a gear so it must engage the gear below then go down another. but instead of giving you power the rpms go up slightly untill the gear is fully engaged. lets say your going 40mph in 5th gear and you floor it downshifting to 4th gear wont give you great acceleration so your cars going to want to put it in 3rd but the car must first go to 4th then 3rd during the 5-3 gear transition your rpms rise since no gear is fully engaged and the rpm must rise to be able to shift into a lower gear. just like if your driving a manual transmission if your in 5th gear and downshift to 3rd your rpms will rise. basically what i think our car is trying to do is what a manual driver does called rev matching or some call it blipping the throttle. the new 7speed mercedes transmission fixes this by allowing the transmission to skip gears while downshifting.
I'll keep that in mind. I'm carpooling this week so I have make time to drive using the recommendations you guys have offered.
Andrew2004az - 8/15/2005 8:45 PM
both of our ML's do the same thing 00ml 320 and 02ml 320. so i know its not related to certian years or cars. i think the c230 loaner car did the samething also.
